Question about Acer NSK8458AN Keyboard
Acer travelmate 4050 keyboard prints wrong keys
When i type a number of keys, not all, they print the wrong charater. For example I type K and get a 2. How can I reset the keyboard or correct this error?
  • Acer Master
  • 4,338 Answers
Hold the Fn key then hit F11. This toggles the numeric nubers to letters and vice versa.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 20, 2009
Brother CM1000 is not working when typing a caracters return wrong one for example when "a" return "fr"?
for em-530
"Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off for 10 seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center.
Dec 04, 2013 | Brother EM-530 Typewriter
Some keys are not functioning..
Dear Friend
If some of the keys are working and some are not or displaying the wrong charaters then there is a problem with your keyboard.
purchase a new one and your problem will be solved.
gagan
Mar 17, 2011 | Compaq Keyboard
I have a Gateway keyboard. On the key that types (? and / , it also types the E with an French accent) How do I toggle to get these charaters)
Click on Keyboard icon on taskbar and change the option to english...Looks like it is in French right now..
Feb 12, 2011 | Gateway 2520915 Keyboard
Keys are not matching up . When i type certain letters, it displays numbers. Example. press k, and displays 2. Must hold funtion key to get correct letter.
Your number lock is on. Look for a small picture that looks like a calculator on your keyboard keys (possibly on one of the F keys at the top). Press the Fn key plus the key with the calculator pic to turn number lock off.
Jul 19, 2010 | Twinhead Durabook N15RI-2 Notebook PC
My keyboard isn't typing most keys
I would reset the bios by using the jumper in the cabinet. Then make sure you have the correct type of keyboard selected and if all of that does not solve the issue, replace the keyboard.
Aug 23, 2009 | Lenovo Keyboard
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Keyboard keys working strangely. The number 2 key has @ on it. If I want type @ by using SHIFT + 2 it prints ' " ' but not @. If I want type back slash on my keyboard, lenovo machine, it prints tilda....
you're using the wrong language/ go to control panel then go to languages regional and change everthing to your country or the original country of the laptop
Mar 05, 2009 | Lenovo ThinkCentre A30 PC Desktop
Keyboard problem
Information about computer keyboards Now with new technology, stuck keys are no longer an issue; ... Given all the above problems
Information about the AT and PS/2 port 1, Keyboard Clock. 2, Keyboard Data. 3, Not Connected or Keyboard Reset
Device Manager information and help Users who have a keyboard with a windows key may also quickly get to the system .... CODE 2 (Second Error)
This should get ya back in to typing again/Good Luck.. Please dont for get to Vote, Thank You.
Dec 19, 2007 | Acer Aspire 3680 Laptop
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Types wrong characters
If the typewriter is typing letters or symbols that you do not type, it is usually because the Pitch Selector is set to "PS". The pitch selector is on the left hand side and has the numbers 10,12, 15 and PS. Place the selector on 10 or 12 and you will be OK.
Also, check to make sure your printwheel is installed properly. Remove it and put it back in to make sure.
Another thing you can try is to clear the memory. To do this, turn off the machine. Place a piece of paper in the machine sideways. Hold down the MAR REL key and while holding it down, turn on the machine. Wait 2 seconds, then let go of the key. The typewriter will start typing. Shut the machine off after about 15 seconds. Then turn it on as usual. This will clear the typewriter's memory and unexpected charaters should not happen anymore.
Jay @ www.granadahillsbusinessmachines.com
Aug 20, 2007 | Swintec 7040 Typewriter
Acer NSK8458AN Keyboard Logo
684 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
