Question about ASUS Eee 4G Notebook
Where is the subscript character symbol @ on Asus Laptop
How to access euro symbol on gateway laptop?
Hold ALT and press 0128 on your number pad (right side of keyboard). That should create the Euro symbol.
Sep 02, 2014 | Gateway Computers & Internet
Steps on how to apply superscript
In earlier version of Microsoft Office (Word 2003), trying to write a subscript or superscript takes quite a time but with the new Word 2007 it's so simple. For those who are writing technical articles face situation to use these subscripts and superscripts in almost every article like mathematical formulae or chemical equations.
What are Subscript and Superscript? A subscript appears smaller and below the baseline (Ex. H2O or X2) while a superscript appears smaller and above the baseline (Ex. X3)
How to Subscript and Superscript in Office 2003 and 2007?
In Word 2003, select the characters that you would like to change. Go to Format menu and Click Font, from the Font tab you have to select subscript or superscript.
In Word 2007, select the character that you would like to change and Click the Superscript or Subscript symbol from the ribbon under the home tab.aviral_srms_14.jpgIn both Word 2003 and Word 2007, you can also use keyboard Shortcut keys to make the characters as Subscript or Superscript.
Superscript: Press CTRL+SHIFT+=
Subscript: Press CTRL+=
If you work on Windows and Office Applications most of the time then these posts on Keyboard Shortcuts for Windows and Office will help you a lot.
Mar 19, 2011 | Computers & Internet
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
Dear Sir , If you start copying a Class 10 / 11
I understand the pain and how difficult it is to work on a science document!!!!!!!!!!!!
By the way if you are using the office suite applications such as Word 2007 or word 2010, you can insert the symbols easily.
To insert a symbol or special character into your document, follow these steps in Word 2007:
1. Position the cursor where you would like to insert the symbol or character
2. Open the Insert ribbon
3. Click Symbol in the Symbol section
4. A menu will appear with a small selection of symbols
5. If you don't see the symbol or character you'd like to insert, click More Symbols
6. Use the controls to select between symbols and special characters. Additional tools on the symbols tab will help you expand or narrow your selection
7. When you find your symbol or special character, click it and then click Insert
8. When you're done, click Close
The symbol or special character will appear at the appropriate place in your document.
Hope this helps!!!
Well, I am helpless regarding developing a keyboard with all those scientific symbols,.LOL
W
Jan 07, 2011 | Logitech 967437-0403 Keyboard
How do I get the Euro symbol on an ASUS keyboard to operate as it is in tandem with the figure 4?
Whenever there is a symbol to the right of a key, using the Alt Gr key pressed down and then that key tapped, brings the relevant symbol up. Also works if you want an acute accent instead of going to character map, i.e. ?, ?
Oct 15, 2010 | Computers & Internet
How do you use/insert the symbols, like the degree symbol?
use the character map.
Start / programs / accessories / system tools / character map
Aug 27, 2010 | Acer 91.63X07.001 Keyboard
I sometimes accidentally switch the keyboard to characters other than standard English. I don't even know how I do this. How do I switch back to the standard keyboard? If I switch the computer off, then...
There should be a sequence that you need to press to change it from one type of keyboard characters to another. Look for a key that has the symbol of a keyboard on it. Most likely this is the key that is causing you the problems. Typically you have to press the Function key that is near the space bar as well as the key with the symbol on it to change it from one character set to the other. Evey laptop keyboard is alittle different than the next when it comes to which keys are "functions keys", so you will have to examine your keyboard to find the correct key on you laptop.
Aug 05, 2010 | HP Compaq Presario CQ50-110US Laptop
Key symbols on Eee netbook do not correlate to text on screen
It is either a software issue or you have the wrong keyboard installed on your laptop.
Oct 06, 2009 | ASUS Laptop Keyboard for Asus Eee PC
HOW CAN I ACCESS EURO SYMBOL ON DELLINSPIRON2000
hold down alt and hit 668 on the number pad. it should look like this £.
this will definitely work.
Sep 18, 2009 | Dell Inspiron 2000 Bottom Plastic Cover -...
ASUS Eee 4G Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
