Question about Microsoft Office 2010
Is there a real key?
OMG!Is a real key?!
    Sergeant:
  • 279 Answers
Yes, it's included with every legally-purchased copy of Office.
Posted on Jan 04, 2014
What is Zoe Maree Hatch charged with. She appears in Hervey Bay, Qld, court today
To mind your own business pete thats what for? Are use for real? Pfff omg !!
Feb 16, 2017 | Cars & Trucks
Tip
OMG! you are the Guru. I have asked just ask online no real help. However, you...
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
on Nov 16, 2009 | Kenmore 24032\24036 Top Load Washer
How do i find if my friend carol marie grevis
OMG is this question for real? Just type in her name in any social media or in your web browser...then sift thru the gazillion people w/same name till you spot her
Nov 03, 2014 | Facebook Social Network
Where is pvc valve on a suzukisx4
look here
https://suzukipitstopplus.com/Products/1209-2009-sx4-service-manual.aspx
or google your real engine name.
here is just that.
2.0 L J20A I4 (petrol)
2.0 L J20B I4 (petrol)
2.0 L D20A I4 (diesel)
omg 3 engines all are 2.0L
so open hood look up, see the sticker there. it tells you whats there.
Jul 09, 2014 | 2009 Suzuki SX4 2.0
Hi and low idle
surging idle, as in out of control
.no year stated, so cant guess. vast years,!!!
Civic what? sub model.
year,
country.
and engine size.
in a real shop , i open hood, see all that and then check my drivers license. omg , im in texas.
Dec 10, 2013 | Honda Civic Cars & Trucks
Wireless is not secure
Step 1 Log into the Router
A device which forwards packets between networks. The forwarding decision is based on network layer information and routing tables, often constructed by routing protocols.'); return false">Router
by entering it’s IP address into a browser. The default IP address is http://192.168.1.1. At the login, enter your username (admin) and password (admin).
Step 2 Click on “Wireless” on the left hand side then click on “WEP” at the top of the page.
tew-432brp_f_1.jpg Step 3 Enter in the desired encryption values then click “Apply”.
Examples:
Authentication type:WEP WEP
Type: Open
System Mode: Hex WEP
Key: 64-bit Key 1: 0000000000
Note: For WEP you can choose ASCII or HEX modes.
64bit ASCII = 5 digit ASCII key.
64bit HEX = 10 digit HEX key. (Can only use letters A~F and numbers)
128bit ASCII = 13 digit ASCII key.
128bit HEX = 26 digit HEX key. (Can only use letters A~F and numbers)
You can also choose WPA
Wi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA
-PSK. The key must be between 8~64 digits.
Authentication type: WPA
-PSK
Passphrase: omg laserbeams pew pew pew
Confirm passphrase: omg laserbeams pew pew pew
Jan 05, 2009 | Trendware TEW-432BRP 54Mbps Wireless...
OMG OMG OMG OMG
the software is fixed.
clearing the queue
Apr 30, 2008 | Microsoft Zune JS8-00001 Digital Media...
Computers & Internet Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
