Question about Frigidaire PLEF398AC Electric Kitchen Range
Plef398ccd Er flashing - Frigidaire PLEF398AC Electric Kitchen Range
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Mar 21, 2015 | Frigidaire Dishwashers
Er S flashing How to fix
Not sure what the "S" is, but on a Frigidaire, the Er fault code is caused by a stuck key on the console. You'll probably need to replace it:
Replacement Console asse 807545702 for FRIGIDAIRE Large Kitchen...
Oct 19, 2014 | Frigidaire Dishwashers
ALL LIGHTS FLASHING ER S
push cancel if that doesn't work cut the power to it for about an hour
Apr 28, 2014 | Whirlpool 24 in. DU1148XTP Built-in...
Frigidaire electrolux model plef398ccd
You will need to replace the control board. Here is he part to order.
All parts come with a 365 day, any part, any reason return policy.
Apr 04, 2013 | Frigidaire PLEF398AC Electric Kitchen...
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
I have a curtis mathes model plef398ccd how much would it cost to buy this T.V.
$50 work great but frame cosmatic don't look that great.$75 buck,if still in exellent conditions as tv work and vey good condition cosmatic looking frame.
Aug 31, 2011 | Curtis-Mathis CM27101S TV
Modle#FD4050LHBI will not run flashes letters-ER
ER indicates a Membrane Switch Failure and the fix is to replace the Keypad and Console Assembly.
Mar 19, 2011 | Frigidaire Dishwashers
My dishwasher is flashing an ER signal
The moisture is probably getting in through a defective door gasket allowing it to leak.
It will burn out your computer board again if left unattended.
Mar 31, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire PLEF398AC Electric Kitchen Range Logo
27 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
