Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Door will not open on bosch next 500 front loader washer
4 Suggested Answers
SOURCE: How do I replace the door seal to a Bosch Front
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Posted on Feb 18, 2010
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
Macmarkus
  • 2605 Answers
SOURCE: CANNOT GET DOOR TO OPEN
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
**The door typically won't unlock as a result of the unit failing to drain due to an obstruction, excessive suds, also the E13 error (though it won't always show up) kind of one in the same...usually, but the pump failing can cause this as well**
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
This is the info regarding the WTVC ( vision ) series Bosch washers which differ from other prior models.
**Unplug the washer from it's power source...safety first**
The next step is as follows,
Following this ( or in reverse order it's your call if you think there may be substantial water still present ) I'd do this step first...checking the pump filter. It may be a good plan to have towels close by, or a wet-dry shop vacuum.
It's as follows...
Then the filter removal...
That should resolve the problem, As I also alluded to before there is a small possibility the pump itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
Regards,
Macmarkus :)
Posted on Apr 25, 2011
My Bosch 500 next washer has a error 4 code
something could be stuck near the impella that drains the water..need more advice send me a message
Aug 24, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Replace door seal loader washing
This video will show you how to change the door seal on your bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My seal is broken. How can I get another door seal?
Bosch Nexxt 500 WFMC3301 Front Load Washer broken
seal.
This video will show you how to change a door seal on this Bosch front loader washing machine and how to
buy parts .
we have all
bosch repairs in our channel
Jan 25, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Wire off around door
This video will show you how to change a door seal on this Bosch front loader washing machine and the best way to get wier back on te door.
we have al bosch repairs in our channel
May 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
500 WFMC3301 Bosch Front Loader
The door for this model of washing machine cannot be changed to open from the left.
Jul 07, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
85 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
