Question about ULINE U-line 2175Rsod 5.4 Cu. Ft. Outdoor Compact Refrigerator With Left Hin
Cannot turn on
Brand new refrigerator. Display shows two horizontal lines. cannot turn it on. tried holding power button for 10 seconds as per manual
What does the blue snow flake mean on the display
If the power /freezer is set the blue snow flake remains lit.
How do use the digital control panel on my Samsung fridge freezer
to turn off for normal operation and power save push and hold power/freezer button for 3 seconds.
Dec 23, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Feb 01, 2015 | Samsung 26.0 cu. ft. French-Door Bottom...
I have a samsung Refigerator RF4287HABP that has an error code SE after a power failure. What should I do.
According to Samsung Customer Support SE stand for Sensor Error... after a power outage... so follow the same procedure as 1e (holding the save energy and lighting button for about 6 to 10 seconds.)
Jan 02, 2015 | Samsung RF4287HABP 28 cu. ft. 4-door...
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
Kenmore elite upright freezer service manual mod# 253.28093800
There is a lock on the display. Try pressing standby button for 10 secs
Apr 14, 2012 | Kenmore Freezers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 | Freezers
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
ULINE U-line 2175Rsod 5.4 Cu. Ft. Outdoor Compact Refrigerator With Left Hin Logo
171 people viewed this question
Top ULINE Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you an ULINE Freezer Expert? Answer questions, earn points and help others
