I'm attempting to set up a Polaroid 5.1 Home Theatre Speaker System. The audio cable supplied (Dual 3.5 RCA phono input) has both a red and yellow jack at either end and should connect to an aux outp
TV: Sharp LC-32LD135K Blu-Ray: LG BP125
5 Suggested Answers
  • 74 Answers
SOURCE: Upgrading dvd to blu-ray - how can I use my existing surround sound speakers?
Unfortunately because your existing system does not have the option of connecting an external source, such as another DVD player, the only option you have is to reuse your existing speakers and purchase another amplifier. Trying to patch another DVD into your existing unit would require a bit of technical expertise which would be more trouble than it is worth. The all-in one concept is convenient but very limiting in terms of expansion.
Posted on Oct 11, 2008
SOURCE: I have a Sanyo 18.5"
OK, the Sound for the TV MUST come DIRECT from the signal "Source" in this case your DECODER, that is where the sound originates from, that an the Video signal.
The signal comes in the antenna, is decoded and sent out the Video out & Audio Out. Now, depending on what type of out put means the type of connection, COMPONENT, COMPOSITE, HDMI, SVHS.
Now BOTH Componet & Composite must also use the Red & White Audio, an HDMI signal usually sends BOTH audio & Video down the same Lead, but NOT always, and sometimes require the red & White Audio also. SVHS, is again a Video only output, and again must use the Red & White Audio, output.
SO to get a signal from our Decoder, to the TV, we then hook the Video & Audio signal to our, Home Theater System HTS, now this takes our Video signal and eventually Outputs it to the TV.
The TV; uses an EXTERNAL Input for the Video, NOT a "Channel input" the "Audio" is decoded and handled by and IN the HTS, and it output's to the surround sound speakers, and NO audio is output from the actual TV speakers themselves.
Now IF you wish for the TV to have a Signal & Audio come from the Input signal, one simply has to have an INPUT Video connection, on the EXTERNAL input, most TV's have more than one, ALSO the Audio must be input on the Audio External INPUT. Both the External Audio & Video Inputs are selected from the TV, selecting EXTERNAL input. This then will provide a Video & Audio signal.
If you were to split the Audio, AFTER the Decoders Audio output BUT before it went into the HTS, and take, one lead to the Audio IN of the HTS, and the other lead goes to the TV's Audio External Input. Red & White. then the TV will have sound coming out of the TV speakers and the surround sound too, if that's what was wanted.
Hope that helps.
Posted on Dec 23, 2010
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
How do i connect my rca thome theater receiver to my toshiba television
1 yellow cable from home theatre Video out to TV video input and push the TV/ video or input button on the TV remote, next take red/white cables and plug one end into your satellite or cable box to audio output and connect those to the audio input on the home theatre. them push the Fucntion button to AUX, should be working after that.
Nov 22, 2013 | Computers & Internet
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
I want to plug in my iPod touch to the DVD player I have, it's an SA-HT930 DVD home theatre sound system. But I don't know how :( can you help me out? I need some pretty easy to follow instruction...
The manual...
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
May 29, 2011 | Panasonic sa-ht930 Home Theater Audio...
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Mar 14, 2011 | Panasonic SC-HT75 System
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Philips dvd home theather,i didn't get a users manual,i can't get the sound to come out with the tv,it will owrk with the radio. lloyd
I will guide you through it.
Just to clarify, When you say sound out with the tv, which are you referring to:
1. DVD built into to the theatre
2. Pay TV
3. Analogue TV ( or digital TV with inbuilt set top box)
4.Digital TV with a separate set top box
Please indicate which one.
TV: ther should be several set of three RCA Sockets on the back of the tv. Look for the red, whit and yellow Phono sockets. do you have these colours and are any of them labelled TV Out or output?
Philips System: Look for an analogue in, Aux IN, or any other unused RCA (Phono) Sockets ( They MUST be red or white!)
Take a set of red and white RCA leads plug them into the OUT set on the TV, and The "INput" set on the Home theatre, select that input on the theatre and your off and racing!
Please clarify first though!
Jan 17, 2010 | Philips Audio Players & Recorders
I have a 50 inch viera plasma tv and just got a 1200 watt home theatre system product number SC-PT960 and have absolutely no idea how to hook it up properly. The instructions in the book are confusing me...
Assuming the TV is up and working on its own, here's the simplest approach:
Find the the Audio Out from the TV - either an optical connection or a dual RCA Cable (probably came with the TV) and connect that to an Input on the home theatre receiver. You'll need the right cable depending on whether RCA or Optical. That gets you Surround Sound into the Receiver.
Then, connect a cable from each speaker to the marked terminals on the back of the receiver -- Front L/R, Rear L/R, Center, Subwoofer, etc.
Check out your speaker connections by trying a radio station - should play through the front speakers OK. Then switch to the input you connected the TV into. Once you get the TV Audio playing through the receiver, you can go to your TV setup screen and turn off the internal speakers on the TV.
Hope this is enough to get you going.
Feb 18, 2018 | Panasonic 1200W 5.1-Channel XM-Ready Home...
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
56 people viewed this question
 Grubhead
Grubhead
