Question about RTO Sole F80 Treadmill
My fan quit working on my Sole 80 treadmill. Everything else is fine. Any suggestions to fix it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
The display pcb board is bad. Replace internal Display board. Might be expensive.You can get used parts at www.usedtreadmillrepairparts.com
Posted on Jan 04, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Posted on Jul 23, 2012
How do I fix a sole F63 treadmill that accelerates to maximum speed after about 30 minutes of use?
usually the motor will be controlled by a triac its a silicon device you apply more volts to a pin to allow more current to flow thru it
between its two other pins
so its used to control the motor speed
its more likely its a problem before the triac
a 'driver' device
i would take the control board out and examine it carefully for any blackened devices
so to rule out this drive chain i would take the board to a service tech like a TV repair guy and ask him to cast his eye over it
i usually get a few beers from people to do this as a bribe
always works for me and you would be surprised
you could take a photo or two as jpg in macro mode of the board
component side and post them and i can cast my eyes over them for free..
Apr 19, 2015 | Sole Fitness F63 Treadmill
Sole F63 treadmill controls won't work
Stuck button or bad hand switch. Remove covers between hand rails and console disconnect both hand switches should fix it.
Jul 06, 2014 | Sole Fitness F63 Treadmill
Fan not working
Your display pcb board needs replacement.....call sole for service
Dec 24, 2013 | Sole Fitness Sole F85 Treadmill
Sole treadmill displays LS1 error as soon as I press start.
follow this steps and fix it. God bless you
Power Supply An inadequate power supply limits a Sole treadmill's speed to 7 mph, even though the display may say it is going faster. Plug the treadmill directly into an outlet without using an extension cord for best performance. If this is not possible, Sole recommends using a short 16 gauge minimum cord.
Belt Too Tight A walking belt that is too loose will slip and one that is too tight runs slowly. Adjust the tension by inserting a 6 mm Allen wrench into the hole in the right end cap at the back of the deck. This gives you access to the tension bolt. Turn the wrench counterclockwise no more than a 1/4 turn at a time to decrease tension or the opposite way to increase tension. Do not tighten more than necessary to eliminate slippage of the belt on the front roller. You must also then adjust for tracking due to increased belt tension by turning both tracking bolts on each side of the end of the rail 1/4 at a time.
Belt Lubrication Sole treadmill belts come pre-lubricated, but after the first 50 hours of use you will need to lubricate the machine again. Use only lubricant sold by Sole. The treadmill can go for another 1,000 hours of use before another lubrication if it is cleaned regularly. If the belt is running slow and you have done everything else, it may be that your belt is ready ahead of schedule. Spread an entire tube width-wise across the center of the deck. The place where your feet hit when walking or running is the ideal location for the lubricant.
Oct 15, 2013 | Exercise & Fitness
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Jan 30, 2013 | Sole Fitness Sole F85 Treadmill
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
My fans on my brand new sole f80 dont come on
1( test the voltage at the terminal of the FAN, if there are the FAN is faulty.
2( test the voltage at the terminal , if there are NOT TEST why NOT coming voltage to the terminal.
3( follow any wires or plug or connector or loose wires, and TIGHT VERY WELL.
4( test FUSE or c. breaker and replace or reset.
5( Try again, and fix it. See the block diagram attached.
However RUN the software caibration for easy diagnostic, troubleshooting, and fix it quickly.
God bless you
Oct 01, 2012 | RTO Sole F80 Treadmill
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
Sole treadmill keeps shutting off and display code reads "System Initializing" After using for 15 minutes
sounds like overheating or memory issues. could simply be a bad connection somewhere. If the time it takes to shut off remains pretty constant then I'd suggest a capacitor on the electronic circuit board is on its way out.
Jan 21, 2012 | Sole Fitness F63 Treadmill
RTO Sole F80 Treadmill Logo
257 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
