Question about Nintendo DS Lite Console
Discolored top screen
Basically, it looks like the red subpixels are being turned on whether or not the color is supposed to contain red.  This happens over most/all of the display, but it's frequently patchy at the bottom.  It used to be that fiddling with the hinge could restore the display, but that no longer works.
To my inexpert eye, it looks like a damaged or loose ribbon cable, but I don't know how hard that would be to fix.  The DS looks fairly difficult to disassemble and if I'm more likely to make things worse than better, I'd rather just keep this one as a "backup" and get a new one.  OTOH, I'd hate to spend the money to replace it just because I was afraid to get my hands dirty.
Any thoughts?
  • seglda Dec 26, 2008
    I have the same problem on mine now. It was a green tint before but now it's red.
  • Anonymous Jan 03, 2009
    I have that same problem!! I hit the back of the screen not so hard and then it usually stops for a few seconds then it starts going red again.Its kinda annoying.
I am having a similar problem with my DS, and it started happening not too long after I got it. Usually, messing with the hinge would fix it... but now it seems like the backlight on the topscreen may not even be coming on, although I can still see outlines of some things and a redish tinge.
Posted on Oct 21, 2007
This does this screen flickering on the top half of the screen and basically when watching tv or anything its almost like a double image from whats on the bottom but it flickers a red color constantly
Your game playing has ruined the television by the looks of it. Take it to a television engineer and ask if they can do anything with it?
Apr 03, 2016 | Televison & Video
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Discolored Sides
Hi,Yes your problem sounds like the DMD board.This is how it works: Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Ths if your tv is a dlp if its a Lcd it will be an issue with your light engine: Here's how your tv works: Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Mar 29, 2010 | Televison & Video
The screen seems to have two of the same image, green and red.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
I have a RCA HDTV MOD.# R52WH73 with three color lines at the top of screen sagging downward in the center. Any ideas on the fix?
You can get the ITC222 convergence option missing repair kit from should repair that issue. The kit contains the parts and the CD with instructions.
Nov 07, 2009 | Televison & Video
Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
My webcam shows only red
basically we use RGB color system so it contains color like red green and ur web cam settings u only increased the content of red color and u decrease the content of green and pls take ur settings and put all three colors to a same means u have number from 1 to 100 and u can give the red green and blue colors up to this put green in 32 and red in 30 and blue in 32......then it will b corrected
Sep 20, 2008 | Logitech Webcam
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Nintendo DS Lite Console Logo
346 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
