Question about HP Photosmart C7280 Printer
B853A8C8 & B8539B14
Printer is new to me. Plugged it in and received this number. B853A8C8 Unplugged and re-plugged it in again, and received B8539B14. There are NO ink cartridge in the printer. Thanks.
    New Friend:
  • 110 Answers
You may try the below steps ...
  1. Make sure the printer is ON
  2. Unplug the power cord from back of the printer .
  3. If you have a wireless router, then power it off too.
  4. Wait for full 60 seconds.
  5. Plug in the power cord directly to a wall outlet ( bypass the surge / power strip )
  6. Also plug in the power cord to back of the printer.
  7. The printer should Power On automatically , if not you may have to press the ON button to do so.
  8. The printer should make noise and then prompt you to install the ink cartridges. Continue with the printer setup.
  9. Power ON the Wireless Router.
  10. If issue still persists, then contact HP for further support as it could be firmware issue
Posted on Jan 02, 2014
4 Suggested Answers
bandana_gyrl
  • 181 Answers
SOURCE: I have an ink system failure. I changed all of
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Sep 28, 2009
JackHeath
  • 1049 Answers
SOURCE: The ink warning light flashes, and won't go off,
A blinking orange light means an empty or incorrectly installed ink cartridge. Ensure that the cartridge is not empty or dried out. Also be sure you installed the number 45 black and number 78 tri color cartridges. The 41 tri-color, for example, looks the same but would generate an error. Also, check that the panel in the back, or duplexer if you have one, is seated firmly in the printer as this can generate odd errors.
Posted on Oct 13, 2009
SOURCE: OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Posted on Feb 22, 2010
Miguel Gonzalez -I Installed new ink, but error says cartridges empty
Search for reset instructions for your printer in internet. If you told us what is a model of the printer maybe someone will help you.
Jul 23, 2012 | Office Equipment & Supplies
I am receiving a cartridge error on an HP OJ 5510 all-in-one printer. I have tried a black cartridge new cartridge to clear the error without success. The color cartridge seems to be okay. I have...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 22, 2011 | HP Officejet 5510 All-In-One Thermal...
My 8250 printer displays error code 0xc18a020a
Solution ....ink System Failure...error 0xc..........
These instructions worked very well for me. If you follow the same instructions exactly,it should work for you too.
1) If you are looking at the printer FROM THE FRONT, remove the right hand side cover. On most HP printers, there are 2-3 tabs on top that will either pop out with a screwdriver under the top cover, or can be removed with screws. Make sure you have the printer powered off and UNPLUGGED.
2) On the front, bottom, right is a separate piece of plastic that is attached to the side cover that should also be removed. Remove the plastic cover from the side at this point, and you should see a circuit board. The following link will show how to remove the printer cover: http://hpphotosmart8250.blogspot.com/
3) There are two ribbon-type connectors on the top [center] of the circuit board that are plugged in directly to the top, inserted towards the bottom of the printer. One is slightly wider than the other. Again, make sure your printer is powered off AND UNPLUGGED. Unplug both of these ribbons [this can be done without removal of the circuit board from the printer, just use care and maybe some forceps or hemostats to help with reinstalling later], and make sure they are not partially plugged in or touching the board.
4) Plug in, and turn back on the printer. A new Ink failure message should come up (the numbers will be different.) Click OK on this, then unplug the printer again.
5) Plug both of these ribbon cables back into their respective connectors. Plug in the printer and turn it on. It should start back up, and REINITIALIZE as if you just turned it on for the first time. [The printer will run for a long time pumping fresh ink through the print heads during initialization, so be sure you have cartridges that are fairly new/full.] The ink status will be correct, and no more ink system failure messages.
6) Put your printer back together...
Nov 02, 2010 | Office Equipment & Supplies
I keep getting a message that the ink container is
try this:
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
May 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
The ink warning light flashes, and won't go off, even after I've put a new cartridge in. I've unplugged the printer, turned it off and on, plugged the cable back in, and it won't go off.
Oct 01, 2009 | HP DeskJet 970cxi InkJet Printer
Ink system has failed 0xc18a0206
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Dec 08, 2008 | HP Office Equipment & Supplies
Printer does not turn on - checked plugs etc - all OK It could be a problem caused by new cartridge being installed.
This just worked for me. Printer would not turn on, no lights, nothing.
Took cartridge's out, unplugged from computer and wall outlet. Waited 5 min. Plugged into wall plug first, printer turned on, plugged into computer and reinstalled the ink cartridge's and pc found new hardware ( printer ) and all was working after that.
Unplugging from wall socket and pc, was what I needed to reset it.
Jul 18, 2008 | HP Computers & Internet
My HP 5550 printer has two brand new HP ink cartridges - 56 and 57. I keep getting Error 1517 saying that the printer isn't getting the ink. I've cleaned off the contacts with alcohol on a Q-tip but still...
I just kept taking out the cartridges and putting them back in again --at least six times. I also unplugged the printer and then plugged it back in. Finally my printer started to work again.
Jul 01, 2008 | Office Equipment & Supplies
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
HP Photosmart C7280 Printer Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
