I want to resetmy asus eee pc to factory settings before selling it. i have tried the following: pressing the reset button with netbook totally turned off and disconnected; pressing the reset button with battery on; disabling the boot booster at F2; trying to reach F9 upon booting both by holding it down and by pressing it multiple times trying to preempt windows. any other suggestion please!!!!
    Sergeant:
  • 236 Answers
Open the display and click the "Shut down" tab in the lower-right corner of the desktop. Click "Yes" to confirm. Then power on your laptop, and press the "F9" key when the logo screen appears. A menu will display with a list of three options. Select the "Restore Factory Settings" option. Select "Yes" when prompted, then press the "Enter" key to reboot. Wait for the system to restart, then agree to the licensing agreement when prompted. Confirm your name, password and time and date when prompted. Then wait as your computer reconfigures. It should now have the original factory settings.
  • Posted on Jan 01, 2014
    • 12 Answers
    SOURCE: T V broke
    4 caps in the stand up shielded module get bulges on top....replace them. Seen it several times.
    Posted on Oct 10, 2006
    SOURCE: ws 55513
    Does anybody have a "how to fix this" for dummies. It appears this is a major problem in Mitsubishi projection sets. I have the WS-65613 and this has recently started. If anybody has a clue on repair,please provide anything. Randy
    Posted on Sep 23, 2007
    • 1694 Answers
    SOURCE: Mitsubishi WS65513 with blinking green light
    Download Chris@ChrisAndNat.com .........T.
    Posted on Nov 09, 2007
    Slinteriors
    • 8617 Answers
    SOURCE: green power light will not stop flashing and tv will not turn on or off
    You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
    Posted on May 16, 2008
    SD Tech
    • 14553 Answers
    SOURCE: I do not use this TV that often, I only turned on
    when set comes on and then goes off: on the front of the set press and hold both the menu and input buttons at the same time for longer than 5 seconds.
    Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
    This is the self check feature this set has.
    Let me know what error code you find and I will tell you what it means.
    SD TECH
    Posted on Sep 17, 2010
    Testimonial: "You are so awesome! Thank you very much :) :)"
    How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
    Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
    Soft Reset
    You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
    Hard Reset
    A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
    Method 1 1. Power the Eee Pad off.
    2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
    3. Continue to hold both buttons until a bootloader screen appears.
    4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
    The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
    Method 2 1. Open the Settings app.
    2. Select Privacy.
    3. Choose Factory data reset.
    4. Select Erase tablet.
    5. Select Erase everything.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
    Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
    How to repair red screen on asus eee pc sea shell
    Remove any discs in the computer.
    Hold the power button down until the computer turns off.
    Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    Remove the battery and unplug the netbook. Wait 30 seconds.
    Reinstall the battery and plug in the netbook.
    Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    Insert the end of a paperclip into the reset button to reset the netbook.
    The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    Create a new Notepad file.
    Type this code:
    taskkill /F /IM dwm.exe
    Save the file as displayfix.bat in the following location:
    C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    Restart your computer.
    hope this helps
    Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
    How to restore asus eee top et2203t to factory settings
    One way to clear an Asus PC of problems or viruses is to restore it to its original factory settings. This will wipe the computer clean and give you a fresh start. The idea of restoring your laptop may be intimidating, but there is no programming involved. In fact, these laptops are designed to be restored in a short period of time.
    1Turn off the Eee PC. Press the power button or select the shut down option from the computer's main desktop screen.
    2.Turn the unit on and press the "F9" when the flash (logo) screen appears. A menu will appear with a list of options to choose from.
    3.Select the "Restore Factory Settings" option from the bottom of the list in the menu and type "Yes" when prompted to verify the reset.
    4.Press "Enter" when prompted by the computer to reboot the system. Wait a few seconds for the system to reboot.
    5.Follow the prompts on screen to accept the licensing agreement and configure your settings.
    Sep 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
    I had to reinstall driver (synaptics) on my recently bought asus u36sd since i managed to delete the driver while removing bloatware with a software. I did get my scrollfunction back but two finger- and...
    Hi Ali.
    you could try this or go to the link at the bottom and have a read up of what else you could try.
    Push the computer's F9 button until the Recovery System window appears. Choose the option for Windows Setup and select Recovery. You should see a message disclosing that you will lose all your files in the process as the Recovery puts the machine back to its original factory settings.
    How to Restore an Asus Eee PC Netbook ' eBay
    www.ebay.co.uk/gds/How-to-Restore-an-Asus-Eee-PC-Netbook-/.../g.html
    asus eee pc 1000he netbook restore factory settings Google Search
    Nov 04, 2017 | ASUS Eee PC 1000HE Netbook
    ASUS Eee PC 1005HA-PU1X-BK Netbook how do fix black screen issue?It has an upper left corner blinking dash_
    Hello.
    Either you have an operating system problem or memory issue.
    First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
    If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
    If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
    If still not resolved, you'll probably need to reinstall your operating system.
    Hope this helps.
    Jun 25, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
    I need to reformat my ASUS
    Some eee pc asus netbook are designed to have an integrated OS reset which means that you can reset it to its factory setting by just pressing on a key.
    Here's what you can try before doing the clean reinstallation. Turn on the computer. Once it's turning on, tap F8. If your netbook has the integrated OS reset, then, it will go to a screen where you can see the set up instructions. Just follow the instructions on the screen.
    If F8 does not work, you need to do the OS reinstallation. You badly need an external dvd drive for that because netbooks do not have that component. DVD drive is needed for the OS reinstallation disc.
    If you can find an external DVD drive, then, read the following tutorials that I made. Just click on the right tutorial.
    1. Windows Vista Installation Guide
    http://www.fixya.com/support/r8738397-install_windows_vista
    2. Windows 7 Installation Guide
    http://www.fixya.com/support/r8451648-windows_7_installation_guide
    3. Windows XP installation Guide
    http://www.fixya.com/support/r8098962-install_windows_xp
    CARLO
    Apr 04, 2011 | ASUS Eee PC 900HD Netbook
    I need to restart the netbook to go back to factory settings
    You will need the following items:
    1. External USB DvD Drive; Can be purchased from local retailer
    2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
    3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
    4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
    5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
    6. Follow the onscreen instructions that are on the restore disk.
    7. After installation of all software, update windows and reinstall all your necessary software.
    8. Enjoy!
    Jan 24, 2011 | ASUS Eee PC 1000H Laptop
    Televison & Video Logo
    18 people viewed this question
    Top Televison & Video Experts
