Question about Philips HTS3372D Theater System
Keeps saying no disc after putting a disc in
I put a DVD in and it shows no disc.
3 Suggested Answers
  • 108 Answers
SOURCE: dvd drive dose not recognise any dvds i put in it keeps saying unknown disc
If your unit is older the optical pick up lens may be dirty or has gone bad. Most Philips units are exchange items only, meaning they replace it under warranty instead of fixing it, if its out of warranty there usually are no parts or service information on them. Philips was bought be Funai and is not the company it used to be. Check if the unit will play a audio CD, if it does the pickup assembly is bad, some will play a CD but not a DVD. You may be able to clean the p/u lens with alcohol and a Q-tip. The lens is under the clamp that holds the disc while spinning.
Posted on May 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: Cleaning Lens
To clean the lens, remove cover, take a cotton swab and dip it in rubbing alcohol and rub cotton swab on lens.
This will clean your lens. If the problem persists after the lens is cleaned, than the laser motor is bad, or the timing is off and will need new mechanism.
Posted on Jun 17, 2009
Camer is not reading disc and not letting me record
Look in the meno setting, resort camera to default settings.
Jul 04, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
M sons xbox keeps showing a message that says open tray when we put disc in ?
main board inside of the dvd drive is bad cause its not allowing the laser to read into the discs. Best thing is to replace the dvd drive.
Jan 11, 2010 | Microsoft Xbox Console
When I put in a disc it says it's loading; however, it keeps showing "no disc".
when I put in a disc it says it's loading, however it keeps showing "no disc"
Oct 27, 2009 | Mintek MDP-1760 Portable DVD Player
It keeps saying unknown disc,every time i put a disc in there every disc that i put in the player...it will not play it...it keeps saying Unknown-disc...including an audio-disc.
hi, try first to insert a clean up CD, and test your Cd or Dvd player with an original CD or Dvd, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
Sserpentio
Apr 12, 2009 | Insignia NS-VDVD1
Dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Mar 14, 2009 | Samsung DVD-V3500 DVD Player/VCR
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
Samsung DVD-VR357 Won't play ANY DVD's
I have the same problem. How do you reset the unit?
Jan 09, 2008 | Samsung DVD-VR357
I put a disc in and in keeps ejecting it. I know It is the proper disc.
Make sure you are using the correct disc, which it shows in the instruction book that came with the unit. Then I hold the button down while it is open and insert the disc. Works for me, and I have four of which I use daily.
Nov 10, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Wrong disc?
for god sake, i want to talk to customer support... you guys don't even have a 1-800 number posted....disgusting.....I am very upset with your cheap product...i guess i won't be buying protron dvd players from now on.....Whenever I put a dvd, it keeps on saying wrond disc and makes a wierd sound....please solve my problem and also give me your customer support phone number
Nicky Patel
Oct 22, 2007 | Protron PD-800 DVD Player
Philips HTS3372D Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
