Question about Jenn-Air Cooktops
Replacing fan switch jenn aire D156
I have to replace a fan switch on the Jenn Aire D156 electric range. The part is no longer made so I canabalized a range I found on craigslist. Sadly, an appliance repair guy took my old parts to "come up with a repair" and I can not get him to return my calls, so I can't get the parts back. I'm uncertain how to reconnect the pins and my owner manuals have nothing about reconnecting the parts. I can provide pics if needed. This is the "rocker" fan switch assembly that sits on the front middle of the cooktop. My grand-daughter put a full pot of pasta water on top of the original switch and it fell thru. I could still use the cooktop, but after broiling a steak one evening, the fan clicked on automatically and wouldn't go off. I've had to cut off the stove with the circuit breaker so the fan didn't run continuously. Seemed stupid to replace a stove because of a broken fan switch, but I even considered it, until I found that the downdraft fan ducting, evidently according to customer review comments, is not the same on the newer Jenn Aire's as it is on the older Jenn Aire's, so that would not be a good fix either! Any help would be appreciated!
    New Friend:
  • 3 Answers
I have a Radio Shack 3-in-one remote control 15-302 and I need codes for Dinex TV..it says it is 4 numbers
Posted on Jan 01, 2014
SOURCE: cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Posted on Jun 18, 2008
  • 1314 Answers
SOURCE: Jenn-Air 8130 installation problem
Rotate the blower to the proper angle
needed for your installation. The blower
can be swiveled 90°. To rotate the blower:
a) Remove the filter from the blower housing
b) Loosen, but do not remove, the nuts
around blower inlet.
c) Rotate the blower housing for the
proper angle.
d) Retighten the four nuts and install the
filter.
try this its general for this type of cooktop
Posted on Mar 30, 2008
jtbjtb
  • 135 Answers
SOURCE: Jenn-Air electric burner goes to full no matter what the setting
This would be a faulty switch. Hope this helps!
Posted on Feb 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: Need To Replace the Cooktop of my Jenn-Air downdraft
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Posted on Apr 29, 2009
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-air cm200 fan switch replacement part number?
Here is the part number for the switch 74009254
May 08, 2010 | Jenn-Air JED8430 Electric Cooktop
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Switch for cook top fan
i think that there is a sub for that switch.
i tried finding it but cannot find the sub.sorry
Oct 11, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktop fan switch replacement
Jun 14, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
JENN AIRE CVGX2423 COOK TOP
short in the fan wirring.. it is not easiy fix . you need to replace the fan and short wieeing.
Dec 19, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cooktops Logo
165 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
