Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Replaced Frigidaire Pure Source 2 filter and it keeps popping out after about 10 min or after about 5 glasses of Water. This is not the 1st time we have replaced the filter. Could it be just a Bad Filter?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
There was a redesign in the Puresource 2 filters (FC100 WF2CBs) that introduced a very very slight mismatch on the latching mechanism used. I've compared them and it's about a 32nd of an inch off. In the back of the socket where the cartridge is you will see two metal clamps. If you push the filter eject button, you will see them manually open and close. That is the mechanism that is not working due to the difference in the redesign. It is a design flaw in the new filters.
I understand it has been corrected but in the mean time, there are a lot of bad ones out there. If it does have this flaw, I've never been able to get them to latch in and hold. My final solution was to build a new sliding lever that would lock over the front of water filter and hold it in place. It's very easy to do. You just need to make a latch.
We are goint to Drill a small ( slightly greather than 1/8") hole about 1" to the right of the filter centered in the middle of the filter vertically. With the filter out, It should be hollow on the right side of the filter and you can reach your fingers around the right side edge and feel where the whole will be. Mark an drill your hole. It's 1/8" thick plastic and is easy to drill. Using stainless steel bolt, nut and washers a 2" flat metal with a 1/8" whole, and tighten it down firm and build a swinging latch. Push the water filter in place and close the latch. If the waterfilter has any room to play, try devising a wedge to hold it in place (the washer will do that, I used a little stickon rubber foot). The latch has to put pressure on the filter cartidge. Now try the water watching it. If done right, the filter will be held in place, no leaks or exploding waterfilters.
If your listening Electrolux/Frigidaire the old design was 100 time superior to the new design. It would be nice to be able to purchase the old model even if it cost a little extra.
Posted on Mar 31, 2014
Basti
  • 1447 Answers
SOURCE: leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Posted on Jul 14, 2008
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Posted on Aug 24, 2008
garing
  • 998 Answers
SOURCE: water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Posted on Aug 10, 2009
  • 65 Answers
SOURCE: Replaced leaking filter but still leaking
Where is it leaking?, at the filter?, at the hook-ups on the filter?
Posted on Aug 22, 2009
honeymokey
  • 3113 Answers
SOURCE: The water and ice tases and smells bad. New coil and filter.
Replace the water supply line with plastic tubing or copper. Do not use the braided metal or vinyl line as they will cause an odor problem.
Posted on May 10, 2010
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Frigidare filter pure source 2 keeps popping out
call frigiadaire about this they have a fix that they pay for the repair because there filter it a little different know.
Aug 31, 2014 | Frigidaire Refrigerators
What problems have you encountered with newly designed Pure Source 2 water filter
I spoke with Frigidaire's Customer Service [(706)860-4110] and they said that the filter was redesigned. A customer needs to get a "service flash" number from the customer service representative. The rep will also provide you with local repair companies who will use the service flash number in order to get reimbursed by Frigidaire for fixing/updating the customer's refrigerator... at no charge to the customer.
Jun 08, 2013 | Frigidaire 1029438 Frigidaire Pure Source...
Where do I find the filter that needs to be changed
Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Pure Source Water Filter inside the refrig. is overflowing
most likely you have a bad filter holder the part the filter connects to,next time send the model number off of the machine so whoever helps you can look up your model and send part numbers to you.
Dec 23, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Aug 22, 2009 | Frigidaire FRS23R4A Side by Side...
Water leaks from the pure source filter
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
My parents frig had the same problem. The steel tabs that hold the filter in place are very small and frail. Heres what I did to solve the problem, at least temporarily. While firmly holding the filter release button, gently bend the tabs together using an extra long pair of curved needle nose pliers.
Apr 15, 2009 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
107 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
