Question about DeLonghi Irons
No steam coming out - DeLonghi Irons
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
My Tefal pro express inon does not steam the generator not making noise and red light comes on
Maybe the steam switch if broken or not fitted correctly dso you can open and inspect it
Sep 11, 2014 | Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
Swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Sep 17, 2009 | Irons
Solenoids workin, steam lines fine, but no steam
take hose off from iron end,press iron button ,breifly! keep tight hold of hose [best to put towel around hose while holding]see if steam comes out.if not hose could be blocked, then take hose from solenoid end and press button .if no steam comes out the solenoid is either faulty or the valve hole inside is blocked,turn off power and take nut off top of solenoid ,check spring and plunger for condition.the small hole may be blocked in the solenoid housing,try a needle in the hole to clear any blockage.
Jun 24, 2009 | Irons
Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Irons Logo
59 people viewed this question
Top DeLonghi Irons Experts
Charles T Nevin
Charles T Nevin
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
