Question about Briggs & Stratton Garden
DIAGRAM OF HOW TO REMOVE THE ENGINE SHROUD ON A BRIGGS AND STRATTON MOTOR FOR A WOODSTLITTER
ImpalerCo
  • 13 Answers
SOURCE: hi i would like a diagram to show valve timing
"3 HP" means nothing. For definitive, need the Model, Type and Code numbers off the engine. But probably 90% of Briggs engines or better are timed with the valves closed at 1/4 turn past TDC.
Posted on Mar 13, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
  • 15190 Answers
SOURCE: My 24hp Briggs and Stratton ohv engine has bent push rods.
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Posted on Apr 12, 2010
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Posted on Jul 21, 2010
How to remove radiator on 2000 Lincoln Continental
RADIATOR
Removal
1. Disconnect battery ground cable.
2. Drain engine cooling system as described.
3. Remove engine air cleaner.
4. Remove upper radiator hose from water bypass tube.
5. Remove radiator overflow hose from radiator and fan shroud.
6. Remove transmission oil cooler line from oil cooler inlet fitting.
7. Remove nuts retaining A/C condenser core to the radiator.
8. Disconnect engine control sensor wiring from the auxiliary electric cooling fan motors and the CCRM.
9. Raise vehicle on hoist.
10. Remove splash shield from lower radiator support and front sub-frame.
11. Remove lower radiator hose from radiator.
12. Remove oil transmission cooler line from oil cooler outlet fitting on radiator.
13. Remove retaining screws for power steering/transaxle oil cooler and position cooler aside.
14. Support fan shroud, radiator and A/C condenser core with a suitable jackstand. Remove lower radiator
support.
15. Position jackstand aside and carefully remove radiator and fan shroud.
16. Remove two retaining bolts for fan shroud at top of radiator and remove fan shroud from radiator.
17. Remove upper radiator hose from radiator.
NOTE: Loosen transmission oil cooler lines while securely holding radiator
connector with a back-up wrench.
18. Remove the radiator.
Oct 21, 2016 | Lincoln Cars & Trucks
How do I change the radiator on a 96 lincoln contiental 32v intech V8 ?
RADIATOR
Removal
support.
18. Remove Radiator
Apr 19, 2015 | 1996 Lincoln Continental
How do In remove carbie from 13hp briggs and stratton
Correct! work your way down to the carburetor, careful not to tear any seals or hoses. once you get the shroud off, mark the throttle and governor linkage and be careful not to bend them. From there on out it should be 2-4 bolts or screws holding it on to the manifold. replacement is reverse of tear down. Model and serial numbers would help me to help you further, if any is needed! Good Luck to ya!
Dec 15, 2014 | Briggs & Stratton Briggs and Stratton...
How do I remove starter from 14 H.P. B&S vertical shaft engine?
Normally it hooks up to the engine at the top side where the flywheel is located..at the top you will find two small bolts..and at the bottom one or two wires..just disconnect the battery cables so no sparks or shorts when removing from the starter..then disconnect the starter wires set aside and then remove the two bolts..it should drop right out...note.. In some cases you may need to remove the engine shroud on the top to get at the bolts...not a hard job..if more the one wire...mark them or draw a diagram as where they were attached..good luck
Oct 21, 2014 | Rareelectrical STARTER MOTOR BRIGGS...
How to change a coolant fan for a 2001 impala
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling fan.
  3. Raise and support the vehicle. Refer to Vehicle Lifting.
  4. Remove the transmission oil cooler lines from the retainers at the bottom of the cooling fan shroud.
  5. Remove the lower fan shroud push pin retainers.
  6. Lower the vehicle.
  7. Remove the right and the left engine mount struts.
  8. Remove the left front fender upper diagonal brace.
  9. Remove the radiator inlet hose from the radiator.
  10. Remove the air cleaner assembly.
  11. If equipped remove the cooling fan heat shields.
  12. Disconnect the cooling fan shroud electrical connectors.
  13. Remove the cooling fan shroud bolts.
  14. Disengage the cooling fan shroud clip from the top of the radiator.
  15. Remove the cooling fan shroud.
Aug 25, 2014 | 2001 Chevrolet Impala
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
