Question about Craig Tower Speaker System For iPod, iPhone, iPad - CHT910
ICraig tower speaker will not turn on from standby
System was not used for several months. The standby button lights when you turn on the on/off switch on the back, but pressing the on button on the top will not bring the unit off standby.
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
How to turn off Compaq R1500 UPS System?
Press and HOLD the power button on/off..until the unit goes into the standby mode...unfortunately there is not a switch on the back of the unit so you are required to literally unplug the unit...which will completely power down the unit.
Dec 30, 2008 | Compaq R1500 ( 295459-001 ) UPS...
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Emerson AV101 System
I'm in the same boat... happened once before, then came back to life. Now it's back to a red standby light and no ejecting tray
Mar 04, 2007 | Emerson AV101 System
Craig Tower Speaker System For iPod, iPhone, iPad - CHT910 Logo
149 people viewed this question
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
