Question about Sanyo Dp32640
Keeps reseting itself
I left my tv on overnight and the next morning I play Call of Duty ghosts and the screen went pixelated and then it's either a loud distorted pop or the sound will repeat itself for about a second or two and then it shuts off within 2 seconds, then the screen goes off and turns back on with the HDMI 1 logo on the top right and it goes back to normal. Now it keeps happening at least once a hour. The sound when it goes off will vary, for example when I watched Breaking Bad a character would say "I need help." but when the tv desides to turn off it will sound more like "I need Helelelelelelelel." and be on loop until it shuts itself off, usually around 2 to 3 seconds. It will then turn back on like nothing happened. I tried to unplug it for a few hours, and I opened the backboard and sprayed some compress air to get out the dust and to check the boards but nothing seems wrong
    Sergeant:
  • 401 Answers
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Posted on Jan 01, 2014
Testimonial: "No I run a HDMI cable not the the composite hdmi ones, and this happens with both my xbox and my direct tv satellite box, so I doubt it's the xbox."
  • 8457 Answers
SOURCE: We were watching TV and the TV just turned itself
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 07, 2010
  • 61 Answers
SOURCE: Sanyo dp42848 turns on, picture comes on then goes
Sounds like a loose connection to the display panel. Did you physicaly move it from the time it didnt work to the time it started working..
Posted on Nov 10, 2010
SOURCE: I have had my Sanyo DP46848 for 3 years now.
Why not return the television back to where you brought from that they rectify the problem.
Posted on Jan 22, 2011
tech4allmen
  • 666 Answers
SOURCE: Hello, I'm having an issue with my Sanyo
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Posted on Aug 30, 2011
  • 295 Answers
SOURCE: Sanyo Plasma DP42746 (No Picture or Sound)
here is how i fixed mine.......first you want to try to watch your fav show..next, stand up find your car or thuck keys..go to front door be sure to lock the door.....next crank car drive to local hardware store and buy 1 cinder block...pay, get your change return home. next open door place keys on table ....ok this is where it gets tricky.....you will need a clear path to the livingroom, den or media room....pick up cinder block straight over your head ...yell really loud peice of ****!!!!! throw cinder block with great force ,,be sure its released at a 10 degree angle...and ththats how i solved my problem....hope this helps
Posted on Aug 16, 2012
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
Screen has green tint , tv was left on overnight and next morning screen was green and stayed that way , how do i fix this ?
Video processor could be locked up do to a small power surge, leave the set unpluged for 40Min, and it will reset back to normal, if it don't then you might have a CRT neck baord that shorted out on the green gun.
Aug 03, 2011 | Toshiba 57H81 57" Rear Projection...
I pressed pause on my dvr. It was during a "unisom" commercial. When I pressed play (not even 5 minutes later) I can still see the word "unisom" even though the show is playing....
That is called ghosting - a defect in the screen panel of the tv. It's caused by a malfunction of the pixels, it will fade out in time. But beware - if the still image is left in place for longer it might be literally burned in the screen with no way of taking it out.
Jul 15, 2011 | Televison & Video
After charging my nuvi 1450LMT for four hours, I disconnected it from the power cord and left it overnight. When I turned it on the next morning, I got the Garmin logo, then a white screen flashed on...
How did you charge it? If you did not use a high power USB charger, try that overnight. A USB charger provides a lot more powr than your PC. Leave it plugged in and off overnight.
If that does not work, Amazon sells battery replacement kits.
Apr 09, 2017 | Garmin Nuvi 1450LMT
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
I have call of duty 4 and it will not find a game when trying to play online. it just keeps saying that it is downloading data
If your connection is very slow, it may take a while to fully download any new maps or updates. I'd suggest leaving it on overnight on the "downloading data" screen and see if it finishes the download by the next morning.
Feb 11, 2010 | Sony Playstation 3 (PS3) Console
My screen went dim.
i did the same and got very annoyed i'd broken it. pretty much gave up on it until i needed a date from the calender some months later and once the battery had drained it seemed to fix itself. i now only charge it for an hour or two at a time
May 07, 2009 | Palm Z22 Handheld
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Sanyo Dp32640 Logo
115 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
