You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Hi it is possible that you Alternator is faulty,if you have access to a VoltMeter ,check the battery voltage in the morning before you try to start it you should have around 12.7 volts for a charged battery if not fully charge your battery again and check the voltage with your car running you should have around 14 volts with the engine reving at 1500 revs.ifyou get around 12 volts then your lights are taking more power from the battery than the Alternator can replace.You could also get your local garage to Drop Test your battery to see if any of the Cells are faulty
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often. There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above. so if your battery can not full charge,this mean you need change a new battery for your laptop http://www.aulaptopbattery.com.au
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Game Boy Advance SP - Charging Light Won't Display
If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
Troubleshooting Steps:
Make Sure the Game Boy Advance SP Isn't Already Fully Charged If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
Make Sure the Outlet You Are Using Works Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
Try a Different Licensed AC Adapter If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
