Question about Microsoft Xbox 360 Console
Disc tray won't close
I find that my xbox had started randomly doing this: When I press the button to open the disc tray, it opens faster than it should be. Then it will not close. It closes about one tenth of the way then stops. It will still read discs but why has the tray started doing this?
    Problem Solver:
  • 7 Answers
Whenever you need help with your Xbox or Xbox 360 accessories, allways check out Xbox Customer Support
The answer to your question is quite long, so here's a link.
Xbox 360 disc tray help
Hope this helps
Posted on May 22, 2009
What do I do it will not Except my games it just kicks them out
It looks like something is keeping the tray from closing all the way or the eject button is somehow being pressed when it closes. Open the tray and get a flash light to look inside to see if there is anything in there that shouldnt be (like maybe a disc that came loose from the tray and is still inside the xbox). If it looks all clear try holding down the eject button when putting the disc in. If that doesnt work try opening and closing it without a disc in. If it stays closed without a disc open and close it a couple times to be sure then try putting the disc in again. If that doesnt work try standing the xbox up on its side and putting the disc in.
The next step I would try is replacing the disc drive. This of course will void your warranty if you do it yourself I would suggest requesting repair from Microsoft if it is in warranty (http://support.xbox.com/en-US/xbox-360/repair/repair-process)
If it is not in warranty try replacing the disc drive (This is pretty complicated. I have done it and honestly wouldnt suggest doing it yourself unless you are very familiar with disassembling and resembling electronics.) Here are instructions http://hardandsoftgaming.wordpress.com/2011/03/12/replacing-a-faulty-xbox-360-dvd-drive-firmware-flash-or-circuit-board-transplant/
If you are not comfortably with doing this yourself find a local repair shop.
May 07, 2013 | Video Game Consoles & Games
I have recently bought the latest Xbox 360 console and it has been fine until recently the disc tray decides to open and close randomly for example i'll be playing a game then the disc tray will open and...
First step is to check and make sure that 1.) There is nothing stuck in the tray slot (even something very tiny can cause issues) and 2.) make sure there is nothing lodged in the open/close button.
Mar 13, 2011 | Video Game Consoles & Games
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My xbox disc tray closes then pops back open, how
what you do is keep tapping A for a min or so... if that doesnt work the unplug your xbox and leave it for a while :)
Mar 21, 2010 | Microsoft Xbox 360 Console
The disc tray of my Xbox 360 console does not open
If the tray does not open when you press the eject button, try to manually open it. To do this:
  1. Unplug your Xbox console from the power source.
  2. Locate the manual release button on your Xbox console.
    For most Xbox consoles, the manual release button is located in a small pinhole to the left of the eject button under the disc tray.
    For some Xbox consoles, the manual release button is located under the disc tray. It can be under the "O" or the "B" in the word "XBOX" that appears on the tray.
  3. Insert a straightened paper clip or other small tool in the hole at an angle to the left. Gently push the paper clip to try to press the manual release button and partially open the disc tray. This may take several tries. Typically, a thin paper clip works better than a thick paper clip.
    If you insert the paperclip in the hole and find an obstacle, this indicates that your Xbox console's manual release button is located in a different area of the console. Look under the "O" or the "B" in the word "XBOX" that appears on the tray. If this is the case, insert the paperclip under the "O" as outlined in step C. If you find an obstacle, insert the paperclip under the letter "B”. The manual release button is located in one of these three locations.
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray
Sep 22, 2009 | Microsoft Xbox 360 Console
Draw won,t open cant get my game out xbox360
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray.
Hope this will help u.
Sep 22, 2009 | Microsoft Premium System for Xbox 360
Starting
xbox 360?
you open the disc tray by pressing the eject button directly above the tray, insert the disc and then close the disc in the same manner. if the game does not automatically start up then you will be required to go to the row that says My Xbox and the very first tab should say the game you have entered. you play it by pressing A
Jan 27, 2009 | Microsoft Xbox 360 Console
Disc tray won't close!
i know this sounds carzy but mine just did that and i pushed it in hard but not too hard and then tried opened it and when i hit the close button it worked
Oct 27, 2007 | Microsoft Xbox 360 Console
Disc tray stuck closed
Is it making the noise like it will open then getting stuck? If so, this can be tricky! It happens with me sometimes. Press the open button and as it goes to try and open push the disc tray in slightly and up and it should pop open, it does with me anyway.
Oct 22, 2007 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
600 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
