Question about PUR RF9999 Ultimate One Pack Replacement Filter
Light doesn't come on after installing new filter
Just installed a new filter let it run more than five minutes, no indicator light is coming on at all
Lights flashing
Replace the lamp. The lights flashing will also indicate what is wrong. Watch how they flash. Go to the manufacturers website and they way they are flashing indicates what is wrong (ex. 3 quick flashes, long continuous flashes...etc.) When you change the lamp reset the lamp counter in the menu and clean or replace the dust filters as well.
Jan 11, 2014 | Sanyo PLC-XP200L Projector
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
Oil filter gasket
Your oil filter comes with a rubberized o-ring. When you take off the old oil filter, make sure you get the old oring with it. If you don't you'll have problems with the new one. Apply a light coat of clean oil to the new filters o-ting before installing. This helps the filter bond to the motor. turn the old filter counter clockwise to remove it. When installing new filter, fill filter with oil prior to installation. Turn clockwise to tighten. Tighten till snug, then give it an extra quarter turn for tightness. Again, make sure you remove the old o-ring from the motor if it does not come out with the old oil filter. No need to take new oring off new oil filter. Just fill, lubricate seal and install.
Jan 17, 2013 | 2000 Lincoln Town Car
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
My Cannon i860 is blinking an amber light five times and then returns to green then blinks amber five times and so on. What is this error telling me?
I too went through all the cleaning processes on my i860 with its amber light blinking five times to one of green. After all that time and effort, I ordered a new head, replaced it, put the old ink carts back in, and presto, worked like a charm. Don't waste time and money doing anything else.
Jul 25, 2010 | Canon i860 InkJet Photo Printer
How much oil do i put in my truck right after i do an oil change auto zone said 3 buckets of oil . but isnt that too much for an ford f250 94-95
The most these trucks take is six and a half U.S. quarts of oil.The safest way to know for sure is to drain all the oil out, remove and install a new oil filter, then install five quarts of your preferred oil.Start the vehicle up and let it run for thirty seconds, then turn it off.Pull the dipstick out and check the level with the engine not running, then top off the oil as necessary.Run it for five minutes to verify that there are no oil leaks, Then Happy Motoring!!! Hope I could help!!!
May 15, 2010 | 1995 Ford F250
1994 Civic DX coupe w/auto trans: engine quits after driving five minutes, with no warning, engine lights or anything. Let it sit for a few minutes, it starts up and drives like nothing happened. New fuel...
Honda had a recall on the distributor itself they dont cover them any more. they are bad about going out i think its just the pick up that goes bad but you have to replace has a unit
Nov 11, 2009 | 1994 Honda Civic
Changing light after installing new water filter
Water Filter Status Indicator Light
(select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the LOCK and WATER
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
PUR RF9999 Ultimate One Pack Replacement Filter Logo
613 people viewed this question
Top PUR Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a PUR Water Dispensing and Filtration Expert? Answer questions, earn points and help others
