My Lipi PB2 passbook printer is not pulling the passbooks inside?
In the beginning I have to off&on the printer to get the passbook to be pulled inside. But now it is completely not working.
  • 5 Answers
SOURCE: how to calibrate epson PLQ 20 PASSbook Printer
How to calibrate epson PLQ 20 PASSbook PrHow to calibrate epson PLQ 20 PASSbook Printerinter
Posted on Feb 18, 2010
SOURCE: How to calibrate epson PLQ 20 PASSbook Printer
how to calibarate epson calibarate epson plq-20 passbook printer
Posted on Jul 22, 2010
SOURCE: passbook printer olivetti pr2 plus installation
kindly gide me how install Olivetti PR2 plus Passbook printer
Posted on Oct 26, 2010
  • 60 Answers
SOURCE: i have face one problem with olivtti pr2e passbook
REQUIRED TO CALIBRATION......
Posted on Feb 02, 2011
SOURCE: how to calibrate epson plq20 passbook printer
pls help how to calibarate plq20 passbook printer
Posted on Feb 12, 2011
How do I get Tally T5040 passbook Printer driver?
Check the manufacturers website (dascom.com):
http://www.dascomamericas.com/Support/Default.aspx?type_id=3&info_id=5&itemid=23&name=T5040&act=4
Jan 07, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
How to use pr2e passbook printer
Try searching "YouTube", www.youtube.com, put "pr2e passbook printer" in the search area. Also try from the Yahoo web site, search on "How to use a pr2e passbook printer"
Apr 21, 2014 | Office Equipment & Supplies
MY LIPI PB2 PASSBOOK READY LED CONTINUOUSLY BLIKS WHEN I SWITCH ON MY PASS BOOK PRINTER
Olivetti Printer Is Required Calibration
1 Open Your Cover Of Printer
2 Than Move Head Left Side
3 Than Push three Key Than Printer Power On
4 Just Some Beep Is Comeing
5 Close Cover Of Printer
6 Press Station 1 Two Time
7 Than Insert Blank Paper
8 Press Station 2
9 Printer Removed The Paper Automatically
10 Than Again Insert Paper
11 Printer Some Printing
12 Than Printer On/Off
13 Than Printer On
Your Problem Is Solved
Regards
yogendra Sharma
Jul 08, 2012 | Office Equipment & Supplies
A PLQ20 passbook printer is not accepting passbook or another paper
Hi, here are two possible solution, kindly follow me and resolve your problem.
You mean that you load paper into the printer tray, but it doesn't pull it into the print, though it's acting like it should, and you get an error on the printer, then most likely your paper pickup/feed from rollers, it may possible that the problem is dusting or worn out. You can try to clean them with a cloth and water or alcohol, otherwise they may need to be replaced.
If your printer just doesn't see that it has paper and gives you a paper out error, then you may have a sensor problem in the printer, or the printer is expecting a different paper size or paper from a different input than what is loaded (depends on the printer), then you may have a programming issue.
I assure you that your problem will resolve easily.
Good Luck
Feb 24, 2011 | Epson Passbook PLQ-20 Matrix Printer
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 14, 2011 | Epson Passbook PLQ-20 Matrix Printer
Is there any spacific printer for cheque printing
no - you can print with any printer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Tally T2250 Matrix Printer
How to calibrate epson plq20 passbook printer
Apr 15, 2010 | Epson Passbook PLQ-20 Matrix Printer
27 people viewed this question
jasbo
jasbo
