Question about Saeco Royal Professional Espresso Machine
There dispensed beans in my Royal have too much water in them - they are not the nice firm round pods
    Habit-Forming:
  • Saeco Expert
  • 147 Answers
Put the grinder level to highter number. If now is on 5 put it on 7
Posted on Jan 14, 2014
My Saeco Royal Professional says coffee beans empty although it is full
hi,
there is a small measuring device between the grinder and the brewer, that measures grind coffee flowing into the brewer. the brewer is the removable part on the right side of the machine.
it looks like that the measuring device is clocked or in worse case broken!.
my suggestion:
1.open the door on the right side
2. remove carefully the brewer/brew unit
3. clean it under warm running water
4. clean out the surrounding area, coffee pan etc.
5. check the measuring device for clocked coffee. it is square, has a small flap and easy to access with the door open. take a soft brush and clean the area, there might be a lot of ground coffee!
6. carefully re-insert the brewer acc. to manual, do not force in place.
7. close the door and use the unit.
you might also remove all beans and clean the burrs, the ground coffee outlet and check that it is free and not clocked as well. otherwise no ground-coffee will reach the measuring device!
good luck!
Sep 30, 2014 | Saeco Royal Professional Espresso Machine
Should I use bean bag chairs instead of sofas in my living room?
Some giant bean bag chairs can be used instead of sofas and in many cases look more stylish and are a lot comfier too. Go for one the the large bean bags featured in the video, fuax leather are cheap, real leather look awesome if you have the budget. 6 epic giant bean bag chairs you really have to see
May 29, 2012 | Furniture
I have a (saeco) type sup 016 royal proof (app # Q95155) cffee machine and i dont know how it works? pls help.. e-mail d0204_duane@hotmail.com... tyvm
Hi, first the water tank must be full. Turn on the power button, wait for it to heat up-approx 2-3 minutes. You must purge the air out of the system by pushing the button for making coffee ,and at the same time you must turn counter-clockwise the steam knob(frother). Until you see a steady stream of water then only your system will be purged of air. Make sure to never run out of water, or you will have to repeat this process over again. You will also have to fill the dispenser with espesso beans. Good luck with purging the air, it`s a little tricky but really worth it when you indulge with a nice shot of Espresso...
Feb 22, 2011 | Saeco Vienna SuperAutomatica Coffee...
Son in law added whole beans in ground coffee slot, I replaced the brew group however the machine makes a noise when turing on and no water comes out after grinding coffee. With the old brew group it did...
The notches should be at 10 and 12 approx. If the noise is a clicking sound you have a broken brew drive, and the gears have to be replaced. The brew unit can't compress whole beans and something has to give.
There are to triangles on the front of the brew unit at the round hole where it piviots. They need to be pointing at each other, if the 2 notches are in the correct position, its ready to install
Dec 02, 2010 | Saeco Royal Coffee Bar Coffee Maker,...
Saeco Royal=,beans do not appear to be grinding, machine whirs for 30 seconds then says add beans have tried 2 different types beans after cleaning bean hopper works first 2 coffees ok then stops
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Oct 02, 2009 | Saeco Royal Professional Espresso Machine
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
Gaggia Classic Espresso Machine
Are you tamping the coffee at all?
The ground coffee needs to be compressed, using a tamper, to form a hard puck that the water will then get squeezed through.
This has already happened to the ese pods so needs to be replicated in the portafilter when you place freshly ground coffee into it.
The plastic tampers provided with your machine are not fit for purpose and a metal tamper is highly recommended. The base of the tamper should be 58mm
Mar 30, 2008 | Gaggia Classic Espresso Machine
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
75 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
