Question about Generic Fly dragon hj2281 blue large 1:34 scale coaxial r/c helicopter w/l
I have a problem with engine
I think it's crush
I am having trouble getting on to Candy Crush and saga. Possibly because my I-Pad is old. Any answers?
dont think its your ipad.the internet is saying cany crush was down for a couple of days so it could have something to do with that.
Dec 05, 2016 | Tablets & eReaders
Driving home from vacation with cargo on roof dash lights came on slip, evo off and check engine light now staring hard it will barely roll over??
Get an OBD2 scanner or borrow one from Autozone and read the check engine code. I don't think you overloaded your engine as you would likely crush your roof before you got to that point. Hard starting and hard turn over indicates that you've got either a fuel mixture issue or an ignition issue, which means you should check your fuel pump, your atomizer, your spark plugs, and your oil.
Aug 04, 2015 | Cars & Trucks
What is the torque spec for a 1978 Ford pinto differential pinion nut?
170 ft.lbs is the minimum; be aware that this differential uses a crush sleeve to set the backlash and the pinion torque is what crushes the crush sleeve. If you don't set the backlash correctly you can grind up your differential gears.
8 Inch Ford Rear End Torque Specifications eHow
Feb 02, 2015 | Ford Cars & Trucks
Why are my ice cubes dispensing faster than my crushed ice. I changed the auger assembly and crush ice is still slow coming out of dispenser.
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
I have gone on many a service call in regards to this issue. People like their crushed ice.
The auger was not the problem. It is the nature of the beast.
Regular ice cubes have more density (Heavy) and exit through the door dispenser with no problem.
With crushed ice, shaved chips they are lite. When you dispense crushed ice the ambient room temperature (warm air) creates condensate and bines the crushed ice together. Fragments of the crushed ice block the dispenser flapper from closing all the way. The flapper remains a little bit open and ices up.
The manufacturers recommend after you run crushed ice that you run cubes through your dispenser to clear the crushed ice fragments.
Well, that solution is from engineers sitting in a office.
The solution is, from a old experienced field technician is: Reach up and wipe the flapper with a dry cloth. Look up and make sure the flapper is completely closed.
If you need a tech call me at 414-306-1362. Glen Burnie, Maryland, USA
Dec 30, 2014 | Refrigerators
Trouble with crushed ice function on ge profile fridge
Replace the bin. I think if you inspect it, you will find some plastic broke off of it.
Aug 18, 2012 | GE Refrigerators
My love had a crush on my friend
Even though your query is not related to Facebook,I feel that i can give some suggestions.
  1. From your name,i presume you are a girl and it is normal that guys have crush on any "beautiful" girl around. He may be loyal to you,but he might look at your friend if she is pretty. It is hard for a guy(including me) to control his eyes/mind when hot/****/pretty girl crosses by or sits nearby. But that guy can control himself from his further actions. If he just smiles to himself after seeing the girl and leaves the place or looks at the work , no problem for his girlfriend or himself. Problem starts only when he tries to talk with her or approaches her.
  2. People can have crush on opposite gender till they find their loved one or till a crush turns into love. But both guy and girl should be strong that once they are into relationship,they would just ignore the crushes and think more on building their relationship,rather than thinking about their crush on someone. It depends on what we give importance - to the girl sitting nearby holding your hand or to girl standing somewhere.. and he should realise that importance.
  3. Do not fight with your friend for the guy. Friendship is kind of relationship too and breaking up with friend is painful too.
Hope you have healthy relationship with your love! :)
Oct 01, 2011 | facebook.com
Who is my crush
Thats easy, Your crush is the person you think about all the time, and talk to when they are not around.
Nov 21, 2010 | Computers & Internet
The check light is on and after starting the engine, i can see oil on the floor
That's not good.
Check engine light could be due to low oil pressure caused by the loss. If you have some engine oil nearby, top-off your car (to prevent seizing) and then get to a local auto parts store or dealer and get them to run the engine code (auto parts store will do it for free, dealer won't).
The engine code should reveal what is wrong, but it sounds, at the minimum, the crush washer that goes beneath the bolt in the oil drain pan needs to be replaced - some times after an oil change a mechanic might over-tighten that bolt and damage the crush washer too much. The crush washer is design to distort to cause an air-tight seal and prevent leaking. Leaking oil would reduce pressure and, in turn, cause check engine light to come on
Nov 12, 2009 | 2001 Volkswagen Passat
Ice maker dispenses crushed ice in the cube setting. Water and crushed ice are fine.
Typical of a switch failure / control module failure so it sticks on the crushed ice setting or the crushing mechanism is u/s and wont turn off. Call a service engineer asap.
Aug 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker stuck on ''crushed'' ice
i think it's simpler than that. there's a plastic gate that snaps UP for cubed and DOWN for crushed.
When you remove the tray, set it to CRUSHED, BEFORE putting the tray back in place.
Nov 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Generic Fly dragon hj2281 blue large 1:34 scale coaxial r/c helicopter w/l Logo
13 people viewed this question
Top Generic Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Generic Heating and Cooling Expert? Answer questions, earn points and help others
