Need easy way to access control panel
How to get to the control panel on Kenmore Model No. 110.20702990
    President:
  • 1,136 Answers
Hi, On this model, the end caps to the control panel snap off. Pull at them from the top and they should release. After there are off, there is a screw in each of the front corners holding the panel to the cabinet. Now the [anel will raise up and rest on the hinges.
I hope this helps.
Vic
Posted on May 20, 2009
How do I remove back to replace control panel on my Kenmore Range Model # C970-615021
A FEW SCREWS ON THE BACK AND ALONG THE TOP OF UNIT, NEED TO PULL OUT FROM WALL TO GET ACCESS
Dec 12, 2014 | Kenmore Kitchen Ranges
Why wont my kenmore microwave model 721.80012401 glass tray wont turn?
you need to replace the motor
usually you can take the plate out and turn the unit over to access it via a small panel
then unscrew it and disconnect
source the correct one on ebay
http://www.ebay.co.uk/sch/i.html?_odkw=kenmore+712&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xkenmore+microwave&_nkw=kenmore+microwave&_sacat=0
you can also use a standard type
just match up the label
it will have like a model number then ccw or cw {clock wise or counter clock wise} so matching the right generic type it easy
Aug 11, 2014 | Microwave Ovens
Main control board
Kenmore model number looks like this 795.51313012 90364894-0494-4d01-a2bd-9abc6a90a2c6.jpg
I am here should you need me, Thanks John Tripp Appliance 911
Apr 23, 2014 | Kenmore Refrigerators
Kenmore washer model 110.24872300, need to romove control panel
if u got rooom just tip the unit back and get acesss underneath it will be a lil bit tighter space to work but will save you the time and hassle of removin the concole......... u will need a part # 285753A- whirlpool motor couplling.... most those consoles remove though by screws on backside corners or front corners, remove those tilit concole back remove brass brackets, wiring lid switch, pull cabinet off hope this helps
Feb 03, 2010 | Kenmore Washing Machines
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Model#665.15829000 kenmore
sounds like you have a stuck key pad on the touch control board. there is no easy way to check this, but you can unplug the "ribbon" strip from the control board. then you will need to jumper the board to see if you can force the unit to run by bypassing the key pad.
i cant find an exact match for your model number, but if you check the wiring diagram, behind the lower access panel, it will show you which 2 terminals can turn on a cycle.
the best thing i can tell you is to just replace the control panel with a touch pad assembly. it could cost about 125-150 bucks, but that should fix the problem.
Jan 30, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore washer continully runs
Hello Friend, Your problem is easily solved. You need to replace the water inlet valve. It's easy to replace the water inlet valve on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you will be able to gain access to the water inlet valve. Simply remove the hose and wires from valve and replace with new one. Re-install the cabinet, control panel etc. This should solve your problem. Happy to help, Tim.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Slow cold water fill kenmore top fill mashine
hi I had the Kenmore washing machine , and now have whirlpool, and have changed the valve on both.
you will need a screw gun or phillips scew driver a ratchet set with 1/4 and 5/16 sockets and a pair of channel locks.
turn off the water valves and unplugg the machine.
disconnect hoses from the wall and drain excess inton washer.
pull machine out and make sure you have enough room to work.
check to see if there are two screws under the control panel. if there are unscrew them anmove the control panel tosee if you have access to two clips that hold the control panel to the back of the machine.
if you remove the clips remember how they came out. then remove the screws and bolts from the back panel.
it is reccomended to change the hoses every year but no onew does that.but since you are working with the valve is would be a good idea.
once you get the rear panel off, the valve should be easy
good luck BRouth3bme
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
