Question about Southern Telecom Lands Phones
No signel or recepication
When the green light is on it quickly goes turn back red all the time.....when the green is it won"t connect
  • 41 Answers
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: SYLAVANIA green light blinks a few times and goes back to red
Funai used lousy wire going from the inverter board to the backlight tubes. Look for any wires that are touching each other. The insulation could have broke down between them and started arching. Get some heatshrink tubing to recover the damaged wires.
Posted on Feb 08, 2010
  • 742 Answers
SOURCE: i have playstation 3 model # CECHH01, a game is
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
Posted on Aug 23, 2010
  • 19 Answers
SOURCE: Apex DT250 wont turn from standby (red light) to On (green light)
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Posted on Oct 08, 2010
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
I can't get my TV to go on.
Check for bad connections but be very careful if you don't know how to do that. It can cost you $10 for labor and $1 for solder if you tell to your neighbor technician that you have bad connection in your tv board. Enjoy
Sep 23, 2009 | Televison & Video
Turn power on press swich at front red goes to green ie on 2 seconds turns off red
Its called the red light of death, turn it back off then hold down the button, it should beep once then beep twice quickly. It takes a few tries
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Lands Phones Logo
14 people viewed this question
Top Southern Telecom Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Southern Telecom Lands Phone Expert? Answer questions, earn points and help others
