Question about Matsunichi PhotoBlitz PF7E Digital Picture Frame
Instructions 2 - Matsunichi PhotoBlitz PF7E Digital Picture Frame
Britax Evolva 1-2-3 instructions
You can find instructional videos and user manuals for the Britax Evolva 1-2-3 here: http://www.britax.co.uk/car-seats/car-seats/evolva-1-2-3-plus
Nov 16, 2012 | Britax Evolva 123 - Chamonix
How to remove my power steering pump
hope this one help http://www.popularmechanics.com/cars/how-to/maintenance/3322636
This instructable is designed into four main parts. Here's the outline:
1) Gather the materials
-- Instructable step 1 - This includes tools, a new pump, fluids, etc.
2) Remove the leaking pump
-- Instructable step 2 - Drain the Power Steering system
-- Instructable step 3 - Remove accessories from Power Steering system
-- Instructable step 4 - Remove the pulley and bolts
-- Instructable step 5 - Remove power steering pump
3) Install the new pump
-- Instructable step 6 - Place the new power steering pump
-- Instructable step 7 - Press on the power steering pump pulley
-- Instructable step 8 - Align the pulley and attach the belts
-- Instructable step 9 - Flush and fill the power steering system
4) Cleanup
-- Instructable step 10 - Cleanup
You'll need some tools to complete this task. Before you start, gather the necessary equipment -- you will not be able to use the car once you start the replacement! It is always a good idea to have a friend on call, or a second car available.
Equipment list:
  • Power Steering pump (to replace defective pump)
  • Two (2) quarts power steering fluid or appropriate ATF (to flush and fill). More than 2 quarts if flushing the rack is desired.
  • Power Steering Pulley Puller set (to remove and attach the pulley). Some auto parts stores will loan the tool sets.
  • Socket set.
  • Open end wrench set (for use with puller set).
  • Leverage pipe or extension bar (in case the pulley is hardened on the spindle).
  • Drain pan (to drain & flush power steering system).
  • Wheel bearing grease for sliding pulley on the pump hub.
  • 2' wood 1x2 for assistance with aligning the pulleys. Any straight tool will work fine -- a level, metal rod, wood, whatever.
Jun 29, 2012 | 2002 Buick Regal
Unlock instructions
You can get the Unlocking Instructions for Sidekick 2 at here Onlinegsmunlock.com/sidekick-2/rs7wp9/ and Unlock it from network lock......
Sidekick 2 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Sidekick 2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick 2 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick 2 with a Not ACCEPTED SIM Card.
2. If your Sidekick 2 asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick 2 will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick 2 is now unlocked.
Mar 28, 2012 | T-Mobile Sidekick II
I lost my instructions for my Pasta Boat and I don't know what power to use or how much water.
For elbow, bowtie, ziti, rotini, and penee
1 serving -1/2cup -water level at #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving size ( serving size - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cook several minutes longer.
and just because I couldn't find this online no matter how hard I tried:
For spaghetti, linguine, angel hair and fettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
cook time servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17
Jan 10, 2011 | Microwave Ovens
Need instructions on how much water and how much rice for rice cooker
answer from page 6 of the instructions: http://www.aroma-housewares.com/manuals/ARC-914S_InstructionManual.pdf
UNCOOKED RICE
WATER WITH MEASURING CUP
INNER POT WATER LINE
1 Cups
1-1/2 Cups
Line 1
2 Cups
2-1/2 Cups
Line 2
3 Cups
3-1/2 Cups
Line 3
4 Cups 4-1/2
Cups
Line 4
Sep 12, 2010 | Aroma ARC-914S 8-Cup Rice Cooker
OLYMPUS MASTER 2 -NEED ENGLISH INSTRUCTION BOOKLET
Hello tilly07596, You can find the instructions for Master 2 at this link: The Master 2 instructions start on Page 39. Reply if you have any further questions or please rate this solution if you found it helpful. Thanks!
Edward
Aug 22, 2010 | Cameras
I have Schiller AT-2 Plus, i need instruction
press Alt then 9 - 1 - 1 for the time.
press Alt then 9 - 2 - 2 for the date
May 09, 2010 | Schiller Welch Allyn Cardiovit At 2...
Need instructions for Toastess cinema popper TCP-6L
1 tbsp veggie oil for 1/3c. corn
2 tbsp oil for 2/3c corn
3 tbsp oil for 1 cup corn
i use 2/3 c as the max because it completely fills the bowl if you use 1 cup be sure to do it in batches or the machine will over flow.
happy popping
Aug 30, 2008 | Toastess TCP-6L Popcorn Maker
Playstation 2 mlb 2005 instructions
Go to this website, www.ign.com. Click on guides then look up mlb 2005. That is the easiest way. If you have a printer go ahead and print the instructions.
Mar 10, 2008 | Sony PlayStation 2 (PS2) Console
Matsunichi PhotoBlitz PF7E  Digital Picture Frame Logo
Top Matsunichi Photography Experts
Tony
Are you a Matsunichi Photography Expert? Answer questions, earn points and help others
