Question about Adaptec AFW-4300B (AFW4300B) Serial Adapter
Driver install - Adaptec AFW-4300B (AFW4300B) Serial Adapter
Cannot install printer driver hp deskjet f380
If you are unable to install the driver software check if there are any driver files that have not been removed from your computer (this might have been installed during the incomplete installation). Also, check if you are installing the correct driver and if you have selected the correct operating system.
Open Change device Installation, and then select the Change device installation settings Control Panel setting. In the Device Installation Settings window, select the option to automatically download the driver.
Get ready for driver installation by connecting your printer to the computer with a USB cable or through your local network. Open Devices and Printers and select your printer's name, if it is not listed, then add your printer to the list.
You can also download the driver software from our website. Double-click the downloaded driver file, click Run and the installation will begin. Follow the on-screen prompts to complete the installation.
The driver software can also be installed from the driver CD. Load the CD in the drive and begin the installation. You can choose between Custom install and Easy install. It always better to install all the features.
Follow the on-screen instructions and install the driver. Check if you can Print a document after the installation. If you are unable to Print, then follow the troubleshooting procedure or call our tech support for assistance. Guideline to install the HP Printer Drivers visit https://goo.gl/wPGPzp
Apr 10, 2014 | HP DeskJet Office Equipment & Supplies
I downloaded the driver from nvidia and it installs but if i put my card in windows wants to automatically install the graphics card and then it doesnt pick up my installed driver
install card in first dont let windows do anything to try and install
run driver from nvidia if windows still trys to override then download the driver and try everything offline if none of that helps and windows overwrite the nvidia driver then you want to go into device manager and roll back driver to the nvidia one
Mar 03, 2011 | Computers & Internet
I don't know how install driver to positivo sim 1025, like a special manner to do it . I tried almost every manner , but work partially only , and if restart, don't have audio driver active
install chipset driver 1st then install then install graphics driver then install audio driver then other driver or install the chipset driver 1st then install other driver using device manager
Jan 11, 2010 | Computers & Internet
Microsoft Bus driver to windows xp
You need to install the chipset drivers before it will take the audio driver.
Go here to Acer support, download and install the chipset driver, then you can install the audio driver >>>>>>>
http://support.acer-euro.com/drivers/notebook/as_5630.html
Good luck
Jun 15, 2009 | Hypertec Phoenix 370/S (HYPH01)...
Sound driver installation problem
HAVE YOU UN-INSTALLED THE PREVIOUS SOUND DRIVER BEFORE YOU TRYING TO INSTALL THIS ONE? IF NOT, AND YOU ALREADY HAVE A SOUND DRIVER INSTALLED, YOU WILL HAVE TO UN-INSTALL IT OR DISABLE IT UNTIL YOU GET THE NEW ONE INSTALLED. THEN SET THE NEW DRIVER AS YOUR DEFAULT DRIVER ONCE INSTALLATION IS COMPLETE.
May 31, 2009 | Compaq Computers & Internet
Pcline 300k webcam with headset xp driver problem installing
Try installing the drivers and then plugging in the webcam - this model is a little "delicate"
To be sure, uninstall any drivers already installed for this and do a clean install.
May 06, 2009 | Microsoft LifeCam VX-3000 Web Camera
Driver Compaq Presario C700 notebook
Only for windows xp steps........
u should always turn off automatic updates.......and install drivers it will be work fine..
I will give u all drivers link....go to hp.com and search it..
for modem -sp33442, for audio-sp35270, for sm bus controller-sp36492, for quick lounch sp38171, for UAA sp32395, for webcam sp37849, download all drivers and install it.
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
wifi driver link:
http://www.atheros.cz/download.php?atheros=AR5007EG&system=1
good luck
Jan 05, 2009 | HP Compaq Presario C700T
Unable to install Audio driver
Have you installed the chipset drivers first?
Apr 12, 2008 | Compaq Presario 700 470024-192 Notebook
have installed XP in Compaq Presario 707TU Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."...
Feb 12, 2008 | HP Compaq Presario v3000z Notebook
Adaptec AFW-4300B (AFW4300B) Serial Adapter Logo
47 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Timothy Van Der...
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
