How to connect apple tv - Audio Players & Recorders
How to Install an Apple TV?
If you have an Apple TV (3rd generation), use
these steps instead.
1. Plug into power. Plug your Apple TV into
power. ...
2. Connect to your other home-theater
devices. Connect an HDMI cable to the
back of your Apple TV. ...
3. Find the pairing screen and connect your remote. ...
4. Pick language settings and choose a setup method.
Oct 19, 2016 | Televison & Video
Tip
How to connect an iPod to a TV
<p>The iPod is a very capable media player personal, but sometimes that tiny screen just does not cut it. Fortunately for owners of iPod, Apple allows users to connect their devices to a TV, so that the videos from your iPod to transmit to the screen. For this connection, iPod owners to buy an extra TV out cable, which is sold in most electronic stores. <br /> <p><br /> <p>1. Buy a cable TV output compatible. Apple sells three TV-out cables, iPod composite cable, composite cable Apple and the Apple Component Cable. See the References section for an iPod TV out cable compatibility list to ensure that you have purchased the correct cable. <br /> <p><br /> <p>2. Connect your iPod to TV out cable TV. Depending on the output cable TV you bought, the cable connects the input of the composite or component input on your TV. Each entry is color coded to the appropriate plug-ins to handle. <br /> <p><br /> <p>3. Connect the other end of the cable to your iPod. The cable consists iPod is connected to the headset connector iPod, Apple, while the other two-plug cables into the wall socket. <br /> <p><br /> <p>4. Turn off the TV mode on your iPod through the opening of "Video Settings" from the "Videos" menu on your iPod and change "TV Out" to "On." <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
Where do I put the activation code on computer? trying to connect my apple TV
Hi Penny
Not exactly sure of your requirement.
An Activation Code usually refers to enabling a paid for service.
Like a game or streaming service like spotify etc
AppleTV is plugged into your TV via an HDMI Cable.
It then accesses your local in home WiFi....
To connect to the internet and your Apple Account.
You will need your WiFi Modem password initially to connect into your home network.
Then set up the AppleTV to connect to your Apple Account with your Apple ID (Username & Password)
Use the free Apple "Remote" App on your iPhone to make it easier to enter text.
Also, this might be good for entering activation codes for joining any App services shown on Apple TV main menu.
Cheers
AppleTV Support
View change or cancel your subscriptions
apple tv help YouTube
Airplay and Apple TV Tutorial
May 26, 2016 | Gateway At&t 2701hgv-b 2wire Hi Speed...
How do I install apple products
Assuming your tv has an HDMI port, you simply need an HDMI cable from the Apple TV to the LG. On the LG, choose the HDMI input you connected to, and follow the prompts to set up the Apple.
Sep 17, 2014 | Apple Televison & Video
How do I stream movies from computer to tv?
Unless you have an Apple computer and an Apple TV, you will need to use a cable to connect your computer to your tv. In most cases, you'll be able to connect one of these three connectors directly to your TV from your computer: VGA, DVI or HDMI.
Once connected, you can extend or mirror your computer screen to your television.
If you have an Apple TV and an Apple computer you can use Apple's AirPlay technology.
Aug 09, 2013 | Computers & Internet
I am trying to connect my new apple tv to my panasonic bt205 ht and then to my samsung tv. As I have only i HDMI socket in my Ht I bought a HDMI splitter. This doesn't seen to work. If I connect the...
The BT205 only has a HDMI Out so you need to connect both your BT205 and Apple TV to your TV either directly or through your splitter (depending how many HDMI Inputs your TV has).
You then need to connect either the Digital or Analogue Audio Port from your Apple TV to your BT205 and select the Audio Output from your BT205 as detailed on Page 27 of the manualat the link below.
http://tda.panasonic-europe-service.com/docs/2z4e3b157ez3z2a0dbz656ez706466z21z3703f025f4fa80ffdb9e5a7957895ca96b778f45/tsn2/data/ALL/SCBT205/OI/812908/rqt9445-b.pdf
This will give you the picture from your Apple TV to your TV via the HDMI and the Apple TV sound to your BT205 via the Audio Port.
Aug 04, 2011 | Audio Players & Recorders
229 people viewed this question
 Grubhead
Grubhead
