Question about Water Filters & Coolers
Need a royal water cooler res 3600 owners manual
Need an ownners manual for royal res 3600 water cooler/dispenser
  • 10865 Answers
SOURCE: Owner's Manual
The Oasis service manual is online in PDF format. Just type this addy into your browser and good luck http://oasis.ie/docs/en/SERVICE_MANUAL_ENDLISH.pdf
Posted on Jan 18, 2009
SOURCE: need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Posted on May 12, 2010
  • 796 Answers
SOURCE: Operators/ owners guide
No but Mezzo can.
Posted on Dec 20, 2013
eventwholesa
SOURCE: avanti water cooler
Water Despencer Avanti wd29ec, the blue water release valve is leaking. It has a constant drip that overflows the water catcher on the 5 gallon water dispenser. what should i do
Posted on Feb 24, 2014
dking333
  • 16 Answers
SOURCE: Cleaner willnot dispense water and vaccum it
dump the old water out and refill with clean water
Posted on Apr 20, 2014
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Haier WDNS401VS manual
My haier does not dispense cold water its dispense warm water
Nov 25, 2011 | Haier Water Dispenser w Fridge...
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Need owner manual for POLAR water cooler with fridge
Sep 25, 2009 | Kitchen Appliances - Others
Hamilton Beach water cooler dysfunction.
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
Aug 06, 2009 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Water Filters & Coolers Logo
46 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
