Question about Bosch Therm 830 ES NG Internal Tankless Water Heater - Natural Gas
My bocsh 830es water heater will be running normal then will kick into a A3 mode no more hot water
  • 30 Answers
Check for a green wire near the top right of your machine. It would loop back to itself with a little black heat shrink on it. This should be far away from the heat exchanger. if its near it, I would recommend pulling it out of the wire clips, and relocating it to behind the control unit on the right side of the machine. Keep it away from heat....its a resistor, and will pop random A3 codes if the heat increases its resistance. Reset your code and you'll be good to go.
Posted on May 06, 2014
2 Suggested Answers
  • 236 Answers
SOURCE: my hot water heater makes garbling noise while
If you have hard water the unit may need to be drained and cleaned due to build up inside the tank
Posted on Oct 10, 2009
Why is there no hot water?
Check the heating elements for continuity.
Feb 13, 2016 | Water Water Heaters
Pvg62 model hot water heater
1) Before calling service technician, Copy following link for Rheem tankless error codes and troubleshoot resources including no-error-code:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Add a comment and say what you discover.
Jan 29, 2013 | Water Heaters
My bosch tankless water heater is flashing ae
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Powerstar Electric tankless water heater, 45-551301, installed in a new home less than 3 years ago. We have always had minor problems with the hot water staying hot, fluctuations in hot and tepid...
Tankless heater are a little frustrating sometimes but this is generally an issue of waterflow I believe. The fluctuations are do probably to the amount of water and rate of water going through the heater. If you have a shut off valve on the cold side of the heater, shut it back about half way. This will slow the water going through the heater and allow the heater to heat it up more efficiently. Then go to the shower, turn the hot on all the way (no cold) and allow it to heat up. Once it has heated up, test it by hand for a good temperature that you like. If it is too hot, turn the cold on just a bit until it comes to the temp you like. If it is too cold turn the hot down just a little (still no cold) and it will warm up. Ideally you should be able to turn the hot on full blast and then just turn on a little cold to get the right temp. Once you learn how these work then it makes it easier. You really cant run the water like you do with conventional hot water systems and expect to get the same results. Also, wanted to give you another little tip. Every 6 mos to a year, you should flush you heater with vinegar for about 30-45 minutes using a small cheap submerible pump like for a water feature in a garde. Just put in a bucket of vinegar and and run a hose to the "in" side of the heater and another from the "out' side of the heater and then back into the bucket. This will circulate the vinegar inside the heater and clean all the deposits that will DOA your heater. Funny how the manufacturer wont tell you this but these deposits will ruin the connectiosn on the heating elements. You can make your heater last for a long time if you do this.
Mar 27, 2011 | Bosch PowerStar AE115 Tankless Water...
Very hot water then it kicks off and I have to frequently reset
Even though the water is very hot do you run out quickly? If so the problem is the 'dip tube' if not it is most likely the upper thermostat.
May 07, 2010 | RELIANCE ELECTRIC WATER HEATER
Water heater won't run long enough for hot water.
Common problem if the thermo couple goes bad.Replace thermocouple with a universial on.A common hardware item.
Dec 14, 2008 | Water Heaters
Burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Nov 12, 2008 | Water Heaters
Bosch Therm 830 ES NG Internal Tankless Water Heater - Natural Gas Logo
75 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
