Question about Garden
Hydro gear repair manual
The drive has nopower. What parts need to be replaced?
2 Suggested Answers
sfgjkhb
SOURCE: repair parts for a royal paper shredder
Repair parts can be found at amazon, click here HSM Get Organized with Continuous Operation and take a look. I hope this helped. Cheers
Miller
Posted on Jan 07, 2015
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Z225 keeps throwing off drive belt, every thing is correct. if it is hydro, how do I know which side, both seam fine, except right side feels more stiff
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jun 01, 2016 | John Deere EZtrak Z225 Zero-Turn Riding...
Transmission does not run forward or backwards, machine starts and blades turn good but mower does not move
Do have a broken belt?
If the pulleys turn but the tractor does not move before you go farther see if you have a broken shear pin in one of the pulleys You may have a transmission that needs work. if that doesn't work out.
Mar 28, 2015 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvarna 2754 ride on mower , the transmission seems to be weak it cannot go up hills it could before . How do i fix this?
most likely the trans drive belt has worn down and is now slipping,maybe tighten or replace.
Dec 24, 2010 | Husqvarna Garden
Craftsman GT 3000 will not drive forward or reverse,belt seems ok
Is it a hydro drive or gears? If hydro the trans-axle is bad & needs to be replaced. It is an easy but expensive job.
Sep 30, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Hydraulics get were they won't lift anything like round hay bales etc.
can be a lot of different problems-check fluid level if low fill to proper level --leak in hydro line-check all lines for leak--air in system -bleed system -wrong hydro fluid in system-check for correct fluid---seal at pump leaking-check around pump--controls leaking not holding allowing back pressure--test controls for internal leaks repair or replace if necessary--hydro pump internal malfunction/valves/piston/gears-pressure test repair or replace if necessary
Feb 01, 2010 | Diesel Allis Chalmers 190xt Tractor...
Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
Garden Logo
225 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
