Question about Electronics - Others
Can't get cbs
I have a lava 2605 antenna and it won't pick up cbs. Also it keeps buffering on neflix
  • 97 Answers
Some TV's have poor amplification of the antenna signal, make sure you have a high quality RG6 signal cable, mount antenna with line of sight to TV tower as any obstruction can affect signal strength, AntennaPoint has directions you can use with a compass. If the signal is still low, try a HDTV booster amplifier. If the antenna is indoors, you need to move it around to find a hot spot that brings in all the channels (preferably in the attic).
Buffering on Netflix has nothing to do with the with the antenna, as you have to connect via the web to receive this service. In my opinion, TV's like Samsung are not very good with streaming video, and you are better off using some other device like an old laptop or external device hooked up to the TV to do this.
Posted on Jan 22, 2014
I'm trying to "cut the cord" and use digital air TV. The problem is it buffers and stutters so badly I can't watch it. What can I do?
Get the correct antenna on your chimney. You need the right band antenna for your region. If your shonky antenna picks up something then you know a decent antenna high up will work fine. The attic is a better location but it has to get through the roof tiles and that maybe too much.
Oct 21, 2017 | Televison & Video
Turns itself off after being on for a while,but after about 20 seconds it comes back on automatically. I have a LAVA preamped antenna hooked to it. Is it the antenna or the analog board?
Try to set it up with no antenna, just the cable or wire as an antenna for a broadcast station. If you can just get 1 station then you can find out if the TV is turning off or the LAVA antenna.
If it goes out and comes back on it could just as easily be the power board.
Don't open it up yourself, there are hazardous voltages even with the TV unplugged!
Jul 26, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
What kind of t.v. antenna I need for an RCA SRS T.V. to get the local and basic channels?
that totally depends on how far the stations are from your location . most will get you about 30 miles The Lava HD 2605 ULTRA Outdoor HDTV Antenna
Mar 26, 2015 | RCA Televison & Video
Why will my digital antenna not rotate using either the remote or manual button?
If the motor has not been turned for a long time the grease on the gears may dry out and freeze the motor.
Mar 19, 2015 | Lava HD-2605 Ultra with G3 Control Box...
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
Red antenna warning indicator light stays on
The red light is a warning of antenna mismatch; when you hold the antenna, you are changing the match between the CB's output amplifier and the antenna. Try it with a different antenna or pick up a 'test light' (or test load) for CBs from an electronics dealer, I've also seen them with CB accessories at truck stops. If the test light fires off and the red light on the CB is dark, the antenna you have is junk.
Aug 01, 2010 | Cobra 29 LTD CB Radio
Im trying to watch full episodes on cbs.com and they keep stuttering or skipping
Could be your internet connection. A slow internet connection can cause this. Test your internet connection at www.speedtest.org Try starting the video and then pause it...see if it continues to load on the progress bar. This will allow the show to buffer. Could be the CBS server also. Try watching the shows on a lower resoloution. Check and make sure your motherboard and video card drivers are up to date. Make sure a virus scanner is not running when you are trying to watch a show...that will slow down your computer.
Sep 08, 2009 | Computers & Internet
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
I bought an RCA 800 converter box and it keeps saying signal is too weak, so I bought a stronger antenna. It didn't work and the manual says I need a smart antenna. I bought the RCA antenna 1500. This is...
try this:
if the antenna is the kind that takes a power adapter to power try moving it away from the converter box and try changing frequeny on antenna this problem is usually for cbs channels...
Nov 12, 2008 | RCA Televison & Video
Electronics - Others Logo
160 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
