Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher stops during cycle. Have to push on door to start again.
When I close the dishwasher door, the dishwasher comes on sometimes, but not always. If it does come on, it will usually stop itself during the cycle. If I push on the door it will start again. I have been using a broomhandle to keep the dishwasher going by pushing on the door.
Jim Goldsmith
Level 3:
  • Maytag Master 2,005 Answers
  • Posted on May 20, 2009
Jim Goldsmith
Maytag Master
Level 3:
Answers
2005
Questions
Helped
736926
Points
6152
Have someone replace your bad door switch
1helpful
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
Stops mid cycle and resumes after I push on the door handle
Rather than a problem with the latch sensor it just might be that something is preventing the door from fully closing properly. Check that there are no obstructions stuck on the door/frame seals and that the seals are in good order. Perished seals can prevent the door from closing evenly and this may cause the problems you are experiencing. Also check that the door itself is not warped or out of alignment, this will also cause such problems.
3helpful
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine....
when you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
Dishwasher problem
First: this is what Whirlpool says!!
And after this at the bottom Is what the repair manual says when I looked it up for you!
Dishwasher is not operating properly
1.Dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
2.Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
3.Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
4.Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
5.Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
6.Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
7.Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
___________________________________________________________
BUT, the repair manual says this
Faulty Pump and Motor Assembly Some models that will not wash or drain often have a faulty Pump and Motor Assembly. If the motor is receiving power from the timer and it is not operating that is the case.
Temporary Work-around:
With the power turned off to the unit, sometimes it is possible to manually rotate the cooling fan on the motor assembly. In certain situations where the dishwasher has set idle for a period of time, this may free the bearings enough that the unit will begin to operate. Where this works as a short term solution in some cases, it is often a sign of things to come. The frequency of the motor seizing will increase until it will simply no longer work.
I think this is a hands job that needs service and hands on attention!
I hope it's not the motor or pump!
How old is the machine?
If they tell you it is an expensive motor then you need to know this!!!!
Let me know how it goes!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
1helpful
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
press START/RESUME.
latched.)
Charts.”
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
2answers
Dishwasher is leaking on the floor during wash cycle
If this is a new dishwasher, then I suggest you call in a warranty issue on this one.
2answers
Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Dishwasher sticking half way through cycle
Crawlmom, it sounds like your door latch assy. and switches are not making properly sometime during the wash. Therefore the two dashes. You want to make sure that the dishwasher is level and securely mounted. Another thing is, on this model, if a key pad is stuck, the dishwasher will stop and flash the stuck key. Im not sure where the red light is coming from. Without being there, I'm leaning on the door switch assy. Check this out first and post back. Catriver.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
