SOURCE: Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
SOURCE: A few days ago the
yes
the positon of minute hand not sync with chime strikes.
you fix the minute hand as 15.minute slower and adjust the current time using time adjuster switch not with minute hand ok.
try it and solve it
SOURCE: How do you syncronize the chimes to the actual
Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
SOURCE: I have a Strausbourg chime mantel clock. It chime
each press of the red button will advance the chime count by one. Advance the chime count to match the face clock
Spoke to a. Lock repair expert and got "permission" to move the hour hand forward 1 hour. Then did the 11 hour time reset using the minute hand. It worked! We were concerned that we would damage the mechanism if we move the hour hand. Thanks readers!
