Question about KitchenAid KUDC03IVWH Builtin Dishwasher
Diswasher wont start
There is power to the unit. Start light is on, unit goes through the motions but will not start.
Manual for EML Series ES100T 3 light motion sensor
The bulbs DO burn out occasionally, even after a short time. There are no markings on them that I can see. I have a unit. If it is the same as yours, it is a 100W 120v 8mm(G8 or GY8) Halogen (bi-pin). They also come in 35, 50, and 75W versions, if you don't need as much light.
Nov 16, 2011 | Cars & Trucks
Does anyone know why a Miele diswasher will start to wash fine and then stop with the inlet/drain light flashing after a few mins? I looked at the pressure stat at the bottom of motor and when i blow in it...
hi,
you may have something rapped around the impellers of the circulation pump causing low water pressure. the unit will start and stop to try to clear the blockage. if the circulation pump is really jammed the inlet/drain light will light. it could be a faulty pressure switch but they are not common to fail.
Hope this helps
May 21, 2010 | Miele 24 in. G638 Plus Free-standing...
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Dishwasher won't start
may be in flood mode. tip the unit sideways and see if water leaks from the base if so continue to tip it until it all drains out, then start it on a wash if it starts you have a component leak that will have to be sourced.
Mar 14, 2009 | Dishwashers
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
Diswasher wont turn back on after being moved - DW Omega 908
Have you checked the door interlock switch to make sure it is not disabling the wash cycle?
Sep 01, 2008 | Dishwashers
Help for my asko diswasher
try holding in the start button for 10 sec to see if it resets,or the board could be faulty part no 8801201
Apr 02, 2008 | Dishwashers
KitchenAid KUDC03IVWH Builtin Dishwasher Logo
18 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
