Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1 clyinder misfiring
1 cylinder misfiring. Could it be plug wire or spark plug. i have replaced dist.cap, wires,plugs.
  • Chevrolet Master
  • 1,045 Answers
It could be one or both of the items you discussed. In addition, did you change the rotor when you changed the cap. If the cylinders have individual coils the coil could be weak as well.
Posted on Nov 18, 2015
2 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: mix spark wire on my v6 4.3 dist cap 1500 chevy
1-6-5-4-3-2
Posted on Feb 08, 2009
96z71-4.3 number one cyl misfire I have changed plugs,wires ,dist cap,rotor button put new distributor#1 injector this truck runs right sometimes and sometimes it dont
Is that what you are reading as the code ? To verify this fault have the engine running, with an insulated pair of long nose pliers and remove plug wire from number one spark plug. Let me know if the engine pitch changes.
Oct 13, 2013 | Car Audio & Video
My 88 cherokee has a miss at around 40 mph. any solutions?
Check for a shorting spark plug wire when the engine is under load. Get a spray bottle of water, and mist some water on the plug wires from the dist. cap to the spark plugs. Rev the engine, and you might see a blue spark shorting to the outside of the spark plug or to the cylinder head. If that checks out, check under the dist. cap for any oxidation on the contacts, or hairline cracks in the cap. Any of these things will give you a misfire under load.
Jul 21, 2011 | 2003 Jeep Grand Cherokee
I have a 98 honda accord 5 spd it has a 4cyl motor vtech i just need to know how to fix a miss fire in cylinder 2 and wich one is cylinder 2
Cylinder #2 is the the second spark plug counting from the right to left.
EX.Below are spark plug on engine
engine
' (oil cap) '
' (4) (3) (2) (1) '
'_________________'
Your misfire can be cause by couple of things but the cheapest way that you can try to fix your car is to do a tune up by replacing:
1)all spark plugs
2)do a oil change
3)spark plug wires
3)distributor cap and rotor
note misfire can be cause by:
1.bad gas
2.spark plug and/or wire
3.distributor cap and/or rotor
4.valve adjustment
5.injector
6.off timing
7.ECM
8.bad wiring(power, ground or feed line)
Jul 08, 2011 | 1998 Honda Accord
Cylender number 1 misfire,
Do a complete tune up.. Spark plugs, wires, distributor cap, and rotor button... If it has coil packs that sit on top of the spark plugs.. Replace the spark plugs and cylinder number one coil
Feb 15, 2011 | 1998 Nissan 200SX
I HAVE 2002 ISUZU AXIOM WITH MULTIPLE MISFIRE. I HAD IT SCANNED AND IT SAID MULTIPLE CYLINDER MISFIRE. SO I CHANGED THE SPARK PLUGS. STILL THE SAME. ONE CYLINDER WAS DEAD. DID A COMPRESSION TEST ON THAT...
Probably you have a cracked or otherwise bad Distributor Cap. I would have changed the dist. cap and rotor first, and probably the wires too. You said you changed the boots, did that include the wires?
Pay attention to the order of wires before removing from cap. Draw yourself a diagram.
Are you sure you returned the plug wires to correct plug?
Jan 17, 2011 | Isuzu Axiom Cars & Trucks
I changed the spark plugs and wires on my chevy s10 2wd pick up, which is a 4 cylinder and now it will not turn over. I might have the wires mixed up on the distributer cap. Can someone show me a picture...
GET A PIECE PAPER DRAW A LARGE CIRCLE TOP UPPER HALF CIRCLE LEFT TO RIGHT WRITE NUMBERS 1 AND 3 BOTTOM HALF CIRCLE LEFT TO RIGHT RIGHT NUMBERS 2 AND 4 THAT YOUR DISTRIBUTOR SPARK PLUGS WIRES LOCATION.STANDING ON SIDE OF ENGINE WHERE DISTRIBUTOR IS LOOKING DOWN AT DISTRIBUTOR 1 AND 3 FIRST TWO SPARK PLUGS TERMINALS NEXT TO ENGINE. AND 2 AND 4 SPARK PLUGS TERMINAL ON CAP FACING YOU. THIS IS CYLINDERS LOCATIONS STANDING IN FRONT OF ENGINE.RUN WIRES FROM DISTRIBUTOR CAP TO PLUGS TO THE ENGINE SPARK PLUGS.
Oct 17, 2010 | Chevrolet S 10 Cars & Trucks
Coil 8 misfire
It if is misfiring on one cylinder. The replace the plug wire first. Make sure plug is good.
If two cylinders are misfiring, then you will want to replace the cap, rotor, or coil pack depending on what you have.
Sep 28, 2009 | 1986 Ford F150 SuperCab
Misfire on #6 and #8 cylinder 1996 Dodge Ram 1500
strip heads off again and remove the valves and check the seats ,regrind the valves and fit new springs and seals ,also check the cam lobes for deformation (wear)
Jun 22, 2009 | 1999 Dodge Ram
Hi, I have a 1997 Porsche 993. Motronic 5.2 M07. I am getting these fault codes 1) 62 misfire emissions-relvant 2) 51 Cylinder 2 misfire emissions-relevant) 3) 54 Cylinder 5 misfire ...
misfire :-------- try checking your 02 sensors /fuel pump and filter.
for 51 cylinder misfire :---
Change the coil. Period. Very easy to remove from the vehicle if it's a 4 cyl. Follow that spark plug wire from the spark plug to the other end. What it's attached to you should replace
for 54 cylinder 5 misfire :---First you have to eliminate the most obvious problems, like spark plug and spark plug wire. If you replace those and you still have a misfire, then it's a good idea to look for a vacuum leak in the intake manifold
Mar 07, 2009 | Porsche 911 Cars & Trucks
1990 Celica GT #4 cylinder is misfiring intermittently
shaft seal in dist is bad may be able to replace might have to replace dist
Feb 18, 2009 | 1990 Toyota Celica
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
49 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
