Question about Vehicle Parts & Accessories
The cruise control ligth do not come on and the cruise not work at all the fuse is fine where is the problem
    Sergeant:
  • 384 Answers
Check fuses
Posted on Jan 01, 2014
My cruise control does not work on 1994 Ford 150. Fuse is fine, where to look next? Thank you
Which fuse ? There are two that supply B+ to the speed control servo ! One is located in the under hood fuse box and the other in the fuse panel inside the vehicle > The fuse may look fine but is there B+ voltage across the fuse . Check it with a volt meter . Check B+ voltage at the speed control servo , Black with yellow trace and P/O wire , what ever color that is . Is there B+ at the control switch ? The speed control servo supply's voltage to the cruise control switch . You can check it at the speed control servo as well . They could be videos on youtube showing how to test it .
Diagnose cruise control failure on 1993 Ford 150
May 31, 2017 | Ford Cars & Trucks
What is the number for the fuse for cruise control in a 04 mountaineer
I have to say that the cruise have a fuse in works in since with the brake pedal. There will be two of them 1 will control the brake lights and the other the cruise control. I believe that the blue 1 is the cruise. Change that 1 and all should be fine. Hope this helps.
Dec 21, 2014 | 2004 Mercury Mountaineer
Cruise control stopped working
Check your fuses. and the vacuum lines leading to the cruise control module. inspect the wires
Nov 11, 2013 | 2002 Mitsubishi Diamante
Cruise control no go when button is pushed
I press the control switch on my 1999 Jeep cherokee. the cruise light doesn't come on and the cruise does not engage. Please offer a solution.
Nov 14, 2009 | 1999 Jeep Grand Cherokee
Want to replace fuse for cruise control on honda crv 2005
The cruise control suddenly stopped working and lites did not come on either, was working fine one day then next day it didnt'. Is there a fuse that might have gone out and if so where is it located?
Mar 28, 2009 | 2005 Honda CR-V
Dodge Dynasty Cruise Control problem
THE 2amp FUSE IS IN THE GLOVE BOX FUSE PANEL.
Dec 29, 2008 | 1993 Dodge Dynasty
Dash Board ligths not working
What year is this vehicle? It might have an ambient light sensor that has failed if it's 90's+,but older it's most likely the dimmer switch. If it's early 80's you should be able to replace it w/o having to removed the dash,just small panel cover nearby.
Oct 25, 2008 | Buick Century Cars & Trucks
Cruise Control
make sure brake lights are working,if working brakepedal switch fine.it is most likley the cruise control cut out switch.blue and white switch on brake pedal.
Oct 20, 2008 | 2000 Ford Expedition
Vehicle Parts & Accessories Logo
13 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
