Question about LG Electronic Window Air Conditioner
Motor making straining sound decreasing air flow what should i do
Wall unit air conditioner works fine for a period of time then motor sounds like its straining decreasing air flow what could be wrong? water still drips outside the unit
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    Do you have this AC installed vertically (on it's end) in the window?
    Guru:
  • 1,524 Answers
Check the voltage.
Posted on May 20, 2009
My home base portable air condition blow cold air for short period I have put the temperature 16° if it blow cold air small then it will cut off and blow warm air and the room temperature is always at 30°...
http://www.royalsovereign.com/customer-support/faqs-frequently-asked-questions/portable-air-conditioner-faq.html
Why does my portable air conditioner cool for a short period of time and then turn off?
Have you extended the exhaust hose with another? The unit can ONLY be used with the included exhaust hose (dryer type exhaust hoses will cause the unit to over heat).
How close is the unit to the wall? If the unit is only inches away from the wall and you are running the exhaust hose out a window, more than likely their exhaust hose bend is at 90 degrees which restricts air flow. In order for the unit to run more efficiently and not overheat, it should be at least 1-1/2 feet away from the wall and the exhaust hose should not exceed more then a 45 degree angle.
Are you exhausting the unit out a hole in the wall? If so, are you using a flap vent on the exterior of your home/office? The flap may be too rigid and not open continuously. The compressor is not strong enough to push the air through and therefore will only run for a short period of time before overheating and shutting off. You should take the flap off the vent and replace it with a piece of screening.
Are you venting it into a ceiling or basement? Does the ceiling or basement have ample ventilation? If the ceiling or basement does not have a way of pushing the heat from the exhaust to the outside, the unit will work for a short period of time and then eventually overheat and shut off. Portable Air Conditioner FAQ Portable Air Conditioner Frequently Asked...
Apr 24, 2018 | Heating & Cooling
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
Noise some times and fans dont work some times
99 out of a hundred times - when the fan motor on a window unit 'makes noise and works intermittedly,' you have a bad fan motor which will require replacing.
Sounds as if the fan motor's bearings are making noise - which - would account for the fan working only part time. The reason being is that the 'bearing noise' you are hearing - is a result of the bearings being wore out - thus it causes the fan motor to heat up and 'go off' - on the internal overload' which is built into the fan motor.
Like I said above - most commonly the 'fix' is to replace the motor.
Jun 09, 2011 | Frigidaire FAC106P1A Thru-Wall/Window Air...
No air flow in duck work
I really need more information, but let me give you a couple of things to think about, after the unit has been off for a period of time, when you first turn it on, does it blow air out of the ducts? And as it runs the air stops?
Simplist problem would be the evaporater coil in the unit is icing up, and not allowing air to flow thru it.
This can be caused by the coil being dirty and needs cleaning, or the blower motor is burnt out, this would make it so there is no air flow at the start-up and there will be no air at all.
The motor could be ok, but a wire loose, or a verity of issues.
With the information, this is about the best I can do.
Wish you the best.
Sincerely,
Paul Gibson
Apr 01, 2010 | Dometic Rooftop RV Air Conditioner
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Whirlpool window unit a/c power comes on but no air comes out
sounds like a bad fan motor or capacitor. mostlikely covered by your warranty
Aug 21, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Air conditioner problem 2001 Dodge Pickup
Hello, It sounds like your hot/cold blend door actuator is either hanging up at times or it's loosing it's calibration range because it's starting to go bad. The ticking noise is most likely the actuator trying to close off the hot air port but is unable to stay closed allowing hot air to mix with the cold. If it's just a weak blend door actuator, it will act up more when the air is on full because it has more resistance due to air flow. If possible try to see if the times it acts up decreases when you start the A/C with low fan speed.
Aug 18, 2009 | 2001 Dodge Ram 1500 Truck 2WD
I have just purchased a new carrier low profile 15,000 unit
is their air flow threw the condenser? with the cover on sounds like its cutting off on high pressure switch restricted air flow.
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Fidgerdare electrtolux air conditioner
have you brought it down for a general cleaning on the 3 year period? if not then that's what it needs now.
the coil is freezing up because of dirt accumulation on the coil. even there is a filter, still with in 3 years it could have accumulated to decrease the airflow thru the coil and freeze it up.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Frigidaire FAC124 wall/Window Air...
LG Electronic Window Air Conditioner Logo
123 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
