Question about Emerson Evergrind E202 1/2 HP Garbage Disposer
Emerson Evergrind E202 1/2 HP Garbage disposal manual
Where can I find a manual?
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
Leaking garbage disposal
1) Where is the leak coming from?
Copy following link for troubleshoot walk thru and replacement tips
2) Add a comment Feb 2013
Feb 10, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
It stopped spinning but the motor made a buzzng noise, then it just stopped all together, now nothing
1) Copy following link for troubleshoot tips and instructions how to install new disposal:
2) Once the motor stops spinning, it will begin to overheat, and that will trip the thermal reset button.
Push reset button located bottom of unit, then rotate disk with broomstick. If motor will not work, then replace unit.
Feb 05, 2013 | In-Sink-Erator InSinkErator Badger 1 1/3...
Cost to replace motor on a badger 5-1 garbage disposer
Yah --- if it is humming - usually means it is jammed -- check it out on the sides of the blades. If it is over 2years with heavy usage - get a new one
Nov 24, 2012 | In-Sink-Erator InSinkErator Badger 5 1/2...
Emerson Evergrind E202 1/2 HP Garbage Disposer Logo
289 people viewed this question
Top Emerson Water Heaters Experts
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
