Question about E-Machines eMachines Desktop PC
How do i unplug big blue cord on tower emachine
Do i pull very hard. will i mess up something,i am scared to pull it out, do i unscrew things on side of plug
  • 451 Answers
You do have to unscrew the two screws on either side of the plug to remove the cord. Hope this helps.
Posted on Jan 01, 2014
2 Suggested Answers
SOURCE: eMachine tower doesn't boot up. Only the fan is running
try replacing your ram.if your ram is bad you wont get no picture on your monitor but your puter will start.2 if you have a video card turn off you puter for a few minutes and plug your monitor to your original display.
Posted on Nov 25, 2008
97x plug removal? Pulled on wires to manifold and did not budge. Are these any different that regular wires? I even tried with pair of pliers and got scared that I might damaged the wires
Try to twist or rotate like trying to unscrew the wire.they get stuck to the plug and need to break the "bond" by twisting you will feel the sticky pop and release.when you go back together use silicone that they make for plug wires to keep it from sticking again. Good luck.
Oct 31, 2013 | Cars & Trucks
Removing interior light cover
The cover is normally a flat piece of glass with clips either side or a round glass knob. Push the clips out of the way and the glass should come off with a little tap. The glass knob unscrews. Sometimes hard to turn. Dont be scared to use multigrips as it is quite tough just be gentle.
Feb 08, 2011 | Whirlpool RF368 Electric Kitchen Range
When i pull to start saw it is hard to pull and feels like the piston is jaming or to much compression. when i pull the spark plug out the pull is easy and smooth and the piston moves easily. no visable...
Try some penetrating oil through the spark plug rotate the piston several times and re-apply the penetrant. Lean the saw sideways with the fuel side down and the exhaust side up, overnight.
Pull the start cord (the next morning) several times. Give the cylinder a quick shot of starting fluid and re-install the spark plug.
Should start!
Best regards, --W/D--
Jan 29, 2011 | Garden
Erorr E000019-0000
the waist toner bottle is full or the waist toner bottle sensor has become blocked. if you know where the bottle is remove it, empty it and then clean off the outside bottle with a paper towel. becareful as the toner has a tendency to make a big mess.
Jun 18, 2010 | Canon IMAGERUNNER 2230 Copier
Door won't close
Unscrew the screws on the inside of the door. You will need a special star looking screw driver head. Unscrew all the screws have a towel or someone to hold the door face so it doesn't get scratch when it comes apart from the stainless side since that is what is attached to the dishwasher. Then look near the top front kind of where the latch would be. There is a black thing it looks sort of U shaped and you'll need to pull that forward. It was a little hard to pull it but u will be able to do just with finger tip. By pulling that forward actually will make that black thing in that female thing on the stainless side move back into the right position. You'll probably need help putting the face back on since the stainless part wants to close. Just use your foot to prop the far side as you aligned the side closest to you and then put the screws back in.
Your problem will get fixed
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Where is the transmission fuel stick to check it
look hard its in the cap as you unscrew it as you remove it from the topup tank its only a short thing.
Oct 28, 2009 | 1997 BMW 7 Series
Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
Jul 25, 2009 | Garden
Shop vac has something plugging hose, I can't disconnect hose
The hose just pushes in. You should be able to just twist the hose and pull it out. After you get it out, try attaching it to the discharge side and try to blow the obstruction out. If that doesn't work, try running a fishing pole or something inside the hose.
Apr 21, 2009 | Shop Vac (464-38-10) Canister Wet/Dry...
Paper jam; paper "wrapped around roller -- OK to pull it out?
simply pull out the power cable then just simply open the back cover and pull gently on the paper.
do not just rip it out... Gently and it should be fine
hope it helps
Jan 05, 2009 | HP Deskjet 6940 InkJet Printer
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
