Question about John Lewis JLCH300 Chest Freezer
I can't drain my JLCH 300 chest freezer
I can't seem to be able to remove the drain
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
Where is the drain plug on a chest freezer
Most freezer do not have a drain plug...it is very possible that you do not have one on yours...
The best way to get the water out is to siphon with a small hose till there is not much left .... then wipe out the rest with a rag....
Tipping the freezer to one corner will help you siphon more of the water out...
heatman101
Oct 30, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
How do i defrost?
You have to remove all the food to a good ice chest with no ice. Pack it as full as you can before starting another one. You may need to put some in your refrigerator freezer. It will stay frozen for several hours while you melt the ice in the chest freezer. You can direct a fan blowing into it to speed up the melting. If it doesn't have a drain to catch the water in a tub you'll have to soak the water up in a towel etc. Don't chip at the ice to break it up quicker. You can damage the refrigeration coils.
Oct 09, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
How do i drain the freezer?
Some freezers have a plastic drain plug on the side that can be removed, but most do not. I have found the easiest way is to **** up any water in the cavity with a shop vac or bath towels.
FYI: An authorized servicer is required to drain the refrigerant from the system and requires specialty tools.
Aug 29, 2010 | Magic Chef Chest Freezer MCCF5WBX
I bought a used model MFC05M3BW5 chest freezer. I
Please see attached link for more info, but it appears as though your model has both an internal and external drain plug. Hope this helps
http://www.youserguide.com/wiki/Electrolux_216657700en-007
Sep 30, 2009 | Freezers
How do u defrost a ge chest freezer
Don't hit or punch the freezer walls ,just unplugged and let the frost melts and this water will go through the drain down to an evaporative pan.Make sure the drain is not clogh if it is clogh put hot water into it or blow it with air pressure.
Aug 13, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Its freezing roun the top and not the bottom?
is this a chest freezer? Thick frost around top? try defrosting unit. DO NOT scrape the ice. Very important to remove drain plug to remove water or frost will very rapidly redeposit
Jul 13, 2009 | General Electric Chest Freezer FCM5SU
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Sep 23, 2008 | Maytag Freezer MQU2057
John Lewis JLCH300 Chest Freezer Logo
Top John Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a John Freezer Expert? Answer questions, earn points and help others
