Question about BYTECC Computers & Internet
What type connector cables come with the Bytecc UHF-421 3.5" USB/FireWire/eSATA Hub?
Cant determine the connector types that interface to the Motherboard.
  • 243 Answers
SOURCE: Motherboard Drivers
What make is your motherboard? If you open up the case and there should be info and model number on it. The just go to the makers website a get appropiate drivers.
hope that helps :)
Posted on Dec 29, 2007
SOURCE: zr 5700 usb connector cable to pc
usb to serial and use old cable
Posted on Aug 28, 2008
charcois
  • 763 Answers
SOURCE: how to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
from your case there are wires to put it on the motherboards pin. you can check your motherboard's manual on where to insert the designated wires to the correct pins.
thank you for using fixya
CHARCOIS
Posted on Nov 10, 2008
bunnydawg
  • 5158 Answers
SOURCE: what type of firewire do i need for my camera?
Was having a look at the manual... no firewire... no usb... special cord that splits into audio and video rca jacks and S-video are your only options
Robert
Posted on Jan 25, 2009
Partstore
  • 34 Answers
SOURCE: I have a JVC GR-D250 camcorder. When I connect
You should have a DV Cable 4-pin to 4-pin firewire (part number VC-VDV204U ) which came with your camera. It would not have firewire on one end and usb on the other. They are two seperate technologies. see http://www.wisegeek.com/what-is-a-firewire-to-usb-adapter.htm
Posted on Jul 24, 2009
CAN I USE MY HARD DISC WITH USB CONNECTION
Yes, you can. You'll need a little more hardware however. You can find "hard drive enclosures" at many computer stores, ebay and electronics stores. They look like these. In order to make this work, you need to determine the physical size and interface of the Samsung hard drive first. Most notebook drives are 2.5" and most desktop drives are 3.5" types (regardless of capacity). You'll need to find an enclosure for the drive size and interface type.
The Samsung drive is likely to be either and IDE type with a SATA (serial) or PATA (parallel) interface. Pictures of SATA cables are here, and PATA cables are here. You would select the enclosure depending on 2.5" or 3.5" size and SATA or PATA interface type. Lastly, would be to choose either a USB connection between the computer and enclosure, or an ESATA type. ESATA simply means External SATA. If your computer offers an ESATA jack on the front or rear panel, you might consider using it as it is much faster than USB. If you do not have an ESATA jack, stick with the USB type. All but the most oldest computers support USB 2.0 standard speeds, newer computers have a faster USB 3.0 speed (5Gbit/S) standard, but this hardware is fully backward compatible to the USB 2.0 & USB 1 speed (480Mbi/S) and hardware standards. If your computer has the original USB 1.x standrad speeds, you might consider purchasing a USB 2.0 or 3.0 expansion card as the USB 1.x standard is very slow (just 12 Mbit/S). Check these links for pictures of ESATA, USB 2.0 and USB 3.0 If you look closely, you can see the slight differences. USB 1.0 and USB 2.0 look identical.
Some enclosures will require / include a power adapter for the drive. Make sure you get what is required to get the drive to spin up properly. After your computer is up and running, connect the external drive to the USB jack and let the computer install drivers as needed; then use it as any other thumb drive etc. ESATA however may be different. In any case, follow the instructions included with the enclosure you purchased.
After copying good data, you might be able to format and scan the Samsung drive and map out the errant portions. Even still, I would not use the drive for important information or day to day uses. If you do, be sure to maintain frequent backups.
May 23, 2012 | Computers & Internet
I have camcorder trv 355e I WANT DRIVERS FOR the same for os windows 7
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 23, 2011 | Sony Handycam DCR-TRV265E Digital...
Usb invalid on the DCR-HC26 when i plug it in to a mac or pc
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Jan 18, 2011 | Sony DCR-HC19E Mini DV Digital Camcorder
My pc cant see the cam , i have win7 &xp , need my pc to read it as divce .
Jan 13, 2011 | Sony DCR-TRV285E Digital-8 Digital...
Hi im trying to transfer 8mm tapes to my computer?i have down loaded new software but when i hook up computer says it cant locate i,link cable?i have hooked up provided usb cable but it wont reconize it?
This type of camera usually downloads better with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras only use the USB connection (if they have one) for stills and can ONLY download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The DCR-TRV265E definately has to use Firewire.
Jan 04, 2011 | Sony Handycam DCR-TRV265E Digital...
I am trying to connect my Sony DCR-TRV10E to my home computer via ilink-USB cable, but my computer does not recognize the Camcorder.... I guess this is due to missing drivers for Windows 7. Can anyone help...
USB and i.Link cables are not the same thing. What Sony call i.Link everyone else calls Firewire, DV or IEEE1394, and it is a different standard from USB with different connectors.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. If you are trying to use a USB cable for video download, then it won't work for this camera. The driver is not the problem, this model is not on the Sony list of cameras that will download video over USB.
There is a Sony tutorial page for downloading at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many Mini-DV cameras.
Jan 02, 2011 | Sony Handycam DCR-TRV10 Mini DV Digital...
I cant transfer my videos from sony handycam dcrhc36 to my computer os window 7 evenafter downloading pmb from sony sitemy computer is not detecting the handycam
You don't say what type of connection you are trying to use. This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable. Confusingly, Sony call Firewire "i.Link".
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Dec 11, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Need instructions on installing u2cr-701
How do t hook the wires for the firewire connector and the usb connector on my mother board they don/t match (ASUS P4C800/P4R800).
May 17, 2009 | Televison & Video
Computers & Internet Logo
48 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
indiana650
indiana650
Level 1 Expert
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
