Someone told me that my acer aspire one d270 can share internet and has tethering but i don't know how to open the tethering..
Tery,
Usually when one tethers it is done from the phone to obtain internet for devices such as laptops, tablets or other devices. There are ways to share internet from computers but that is usually done over the network and could not confirm it could be done with a phone. That being said, If you are indeed looking to Tether the laptop to the Phone's internet it would depend on the phone you were trying to use to determine how this would be easiest done.
Depending on the phone some are designed with a Hotspot mode that can be found under the settings of most smartphones and will allow you to access it as a wireless access point. This is contingent on the phone service vender as it will charge you data to use this technology.
If your phone does not support any type of "Hotspot" mode then we would be looking at the possiblity of connecting the phone via USB to allow for internet passthrough. Again this is all depending on the type of phone.
If you can inform me of the type of phone you have and exactly what you hope to achieve I would be more than happy to help further.
-Rogue
SOURCE: VZ easy access loaded but can't open on aspire one
If you have the VZ icon on the task bar, right click it. then click on show application, let it find the network then click connect. Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
The Android Wi-Fi Tether application turns your phone into a Wi-Fi hotspot--essentially aMiFi--in one tap. The catch? You have to gain root access to your phone, a multi-step process that uses an unofficial Android add-on which can brick your phone if applied incorrectly. Rooting Android is doable for geeks and hackers with experience soft-modding hardware, but it's not something most users could (or should!) do.
Method 2: Tether Android with Proxoid (Free, no root required, some configuration
If you don't want to gain root but know enough to get around the command line and use proxy servers, the Proxoid Android app can tether your phone for free.
Method 3: Tether Android with PdaNet ($30, no root required, minimal configuration
Finally, the PdaNet Android application lets you tether Android using an app on the phone plus simple software you install on your computer
