T.cragg61@btinternet.com I cant sigh in to my bt email ,acc
Btinternet rejected my password to obtain my E mails
If you normally use an email program like Outlook or Mac Mail, try logging in to your webmail. If you can see your webmail OK, then it's likely to be a problem with the way your email program is set up.
http://bt.custhelp.com/app/answers/detail/a_id/49512/c/7339/session/L2F2LzEvdGltZS8xNDc4MjExMzgzL3NpZC96SVllVUwybg%3D%3D
may need to reset password if you can't get into web mail
if you can check the authenication method you selected in the email program
from
http://bt.custhelp.com/app/answers/detail/a_id/9962/c/7339
IMAP incoming server option
Incoming Mail Server: mail.btinternet.com
Port: 993 (this should be automatically populated if you tick the SSL Encryption)
SSL Encryption: Enabled (but not STARTTLS)
Username: your email address including the @btinternet or @btopenworld.com part
Password: your btinternet password
Root folder/path:
POP3 incoming server option
Port: 995 (this should be automatically populated when you tick SSL Encryption)
POP from folder: By default, POP will pull emails from your Inbox
SMTP outgoing server
Outgoing Mail Server: mail.btinternet.com
Port: 465 (this may not be automatically populated on selection of SSL, so you'll need to check this)
Authentication: PLAIN
Nov 03, 2016 | Computers & Internet
I cannot get or send emails. my server is not working
This indicates either an incorrect password or server settings. Make sure your account is setup as follows:
IMAP
Root folder/path:
Folder separator: . (full stop)
Please do NOT enable "secure password authentication" (SPA). It's not needed when you use SSL encryption and won't work.
If your IMAP client supports it, we recommend you also set up the following folders:
Trash
Sent Items
Drafts
POP3
Port: 995 (this should be automatically populated if you tick SSL Encryption)
SMTP
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Feb 22, 2015 | Computers & Internet
Cannot log into my btinternet account
Hi
To log into your btinternet account, you now need to go to the BT homepage and click on My BT on the blue bar and log in with your BT email address and password. If you do not know your password then there is a link just below the password box which says "forgotten password" and which will allow you to reset the password.
Cheers
Sep 28, 2014 | Computers & Internet
Timwilko1@btinternet.com
Make sure you're not blocking cookies or popups in your browser.
Sep 05, 2014 | Yahoo Computers & Internet
Www bt com help
Make sure you enable SSL encryption.
SMTP
Aug 02, 2014 | Amazon Kindle Fire HDX 7
How do i copy btinternet.com emails to outlook.com
Email them from the btinternet site to you outlook email address using FORWARD. Otherwise copy/paste the text from bt into outlook and then email it to your self.
Jul 15, 2014 | iPhone Apps
Keith1andlynne@btinternet.com
Go here and follow the instructions for forgotten password
https://signin1.bt.com/login/emailloginform
Apr 12, 2014 | iPhone Apps
Sending email
here are the settings for btinternet, if you use "outlook" you must manually configure them!
  • The POP3 server (incoming mail) is mail.btinternet.com
  • The SMTP server (outgoing mail) is also mail.btinternet.com
  • Both need your BT Yahoo! email address and password; you will have to tell your e-mail program that the SMTP server requires authentication.
  • The SMTP server can use either port 25 or port 587.
The most common fault is to provide your ADSL username and password when your BT Yahoo! username and password is what's required.
good luck and regards
Nov 21, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
