Question about Garden
Craftsman snowblower 179cc china motor
Has very few hous and it will not start and back fires. what is the valve adjustment for this motor
    Problem Solver:
  • 19 Answers
What is the model and serial number off the engine ??
Posted on Jun 05, 2014
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
Electric snow blower stopped working
Maybe it needs to be plugged into a wall outlet
Feb 16, 2014 | Craftsman 21" 179cc* Single-Stage...
Craftsman 179cc ohv 2 stage snowblower loses power in second stage throwing heavy snow
You should check for belt condition and adjustment. Under more load the auger/impeller belt might start to slip and would result in poor performance. For improved performance in wet slush there is an "impeller modification" that can be found with a web search. It's adding rubber wipers to the impeller blades and it does a great job of tossing that stuff out the chute instead of clogging it.
Feb 13, 2014 | Garden
Replaced shear bolts now engine will not turn over
Well look in the Housing to see if ther is something stopping it from turning over or the chain is stuck in drive and not movin
Feb 06, 2014 | Craftsman 21" 179cc* Single-Stage...
Auger keeps spinning after releasing handle
so what is your question as long as it is spinning when you are using it and it is throwing snow so what
Jan 26, 2014 | Craftsman 21" 179cc* Single-Stage...
Craftsman snowblower 179cc ohv
clean the carb , make sure you are shutting off choke after start this fouls the plug , good gas ?
Jan 11, 2014 | Garden
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Won't start after replacing the scrape plate. Yes I tipped it back to get at the bolts on the plate.
pull the spark piug to be sure it isnt flooded withh gas
push the drain on bottom of carb you may have got some dirt loosened up and into carb
Dec 17, 2013 | Craftsman 21" 179cc* Single-Stage...
I need to know how to adjust the governor on my MTD model 31A-62EE729 snowblower with a 179cc motor
lossen the nut on the governor shaft, and move the arm toward the carb while holding the arm in this position turn the shaft counter clock wise and tighten the nut. and you are done. GOOD LUCK
Sep 03, 2013 | Tecumseh Snowblower Snow Blower Starter...
Adjusting a Craftsman Snowblower Carburetor
crafsman snow blower have choke on to run it
Dec 17, 2008 | Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
