Question about Horizon T1201 Treadmill Walking Belt
No power to display on T2101
The display is not lighting up. The speakers have power.
The factory radio in my 2007 Mercury Mariner Premier just quit playing audio all together. It still has power, lights up, displays the station info and all buttons appear to work via the display. It s
could be the speaker out put has come loose at back of radio as to have all speakers blow at once is just to much of a coincedence so pop the radio out and check wiring connentors if all ok looks likely the radio is needing replacing
Apr 28, 2014 | 2007 Mercury Mariner Premier 4WD
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
What are code T2101 and T1516
p2101 Chevrolet Throttle Air Control Motor Position Too Low
p1516 Chevrolet TAC Module Throttle Actuator Position Performance
Sep 22, 2011 | 2005 Chevrolet Colorado
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
Amp lights up (display) and then fails to switch
You need to replace the power amp transistor or mosfet. Bring to electronic technician for repair.
Jul 24, 2009 | Sony STR-DE998 7.1 Channels Receiver
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
Power on and Get the Display panel lights up like christmas
That is an internal fault, with it's power supply. They shutdown if an in-balance is detected.Also check the speaker wire connection - will do the same thing if disconnected or shorted.
Nov 01, 2007 | Samsung HT-Q70T System
Horizon T1201 Treadmill Walking Belt Logo
16 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
