Question about Altec Lansing M602 (021986953371) Docking Station
Buttons stuck late cleansing m602
How to take apart to fix stuck buttons
Shake it
Posted on Jan 01, 2014
Hi how fix the sensitve buttons o the tv because the remote control works but the tv act like crazy and jump from a chanel to other enter in menu and stuff like this
Hi, sounds like you have a late model CRT. It is possible that an OTA update has crashed firmware maybe?
If the tv can be reset to default try it. If that does not resolve the issue you may have to have the set diagnosed. It does not soung like the tuner or any of the major mainboard components. Might be fixable with a firmware update if it is modern
GOOD LUCK
Jun 16, 2015 | Televison & Video
How do I fix repeated paper jams?
Had the same problem with a HL-2140N. My solution was, after unnecessarily taking the whole printer apart inspecting the paper path and assemble it again afterwards, to check if the manual feed would still work. As this worked without a problem, I fuzzily guessed that something had to be wrong before that point.
In my printer, only the separation pad, and the roller right next to it came into question (both mounted at the front of the paper tray). I cleaned the separation pad (ultra fine paper dust gathered over the years) with cleansing alcohol, and took apart the roller assembly next to it (same kind of dust).
Especially the latter was super dirty. I took the roller out to clean the cleansing pad below it with an old toothbrush (Meridol Soft), reassembled, de-greased the roller with some cleaning alcohol, put everything back in place, and my printer works again the way I would expect it too.
Jul 15, 2014 | Brother HL-2150N Laser Printer
How do I fix the top clear toggle buttons if they are stuck?
It fairly easy to take it apart, but please note that there will be alot of small buttons, rubber cushions and guides that will come loose in the opening of the PSP. It could be dirt that cuase it to not fuction correctly or the pressure mechnism is warn out, but easy replaceable. The following videos might guide you how to.
Apr 23, 2014 | Sony PlayStation Portable (PSP) Console
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
Temperature switch will not work
The unit in the dash with the buttons gets dirty. You can remove it from the dash, take it apart and clean the pads under the buttons and I have had 100% success fixing the problem
Dec 12, 2012 | 1990 Buick Reatta
PSP buttons
take it apart and clean the button and if that does not work buy a replacement
Feb 11, 2012 | Sony PlayStation Portable (PSP) Console
Some of the buttons (Start, Select and sometimes Home), don't work. What's the problem?? And sometimes, in game, home keeps showing!
the buttons are stuck take it apart and clean them and if that does not work buy replacement buttons from ebay or amazon
Jan 30, 2012 | Sony PlayStation Portable (PSP) Console
L button stuck
take it all aPART AND PUT IT BAK TOGETHER AGAIN THIS WILL FIX IT OR BUY REPLACEMENT BUTTONS OFF INTERNET
Nov 26, 2010 | Sony PlayStation Portable (PSP) Slim...
Self Cleaning Amana wall oven installed in late 1999 Has worked very well until recently when buttons are pushed to do bake, broil, time etc it won't work when time button is pushed to start. What is...
TRY THIS... If the buttons are "stuck", the glass panel may have shifted to the right or left causing the holes in the glass (through which the button protrude) to rub against the glass. VERY CARFULLY try to shift the glass so the buttons are centered in the holes.
Oct 31, 2010 | Ovens
TV changing channels
check channel up & down buttom if stuck up. if not, replace eeprom as possible. good luck!
Nov 27, 2007 | Insignia NS- 27" TV27 TV
Altec Lansing M602 (021986953371) Docking Station Logo
135 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
