Cmv ct 529a
I am trying to use my monitor for cctv. the message comes up on screen OUT OF RANGE. the h is28-63 khz and the signal from cctv is 64 khz. can i change the range?
SOURCE: signal out of range
need to install the driver!
Posted on Dec 04, 2007
  • 103 Answers
SOURCE: Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Posted on Feb 04, 2008
Mark_Webber
  • 472 Answers
SOURCE: no signal - out of range
Start the computer.
After the ios info page/motherboard page is gone, start to press F8 a few times.
If you still get to the point that you see the Windows Logo loading screen, then press reset and try again.
If you have done it correctly, you will get to the Windows boot page.
Select Safe Mode and start Windows
Go to the video properties page by right clicking anywhere on the screen and adjust the video mode to 640x480 (or as low as it will go)
Restart the computer and see if that solves the problem.
If not, then do the same procedure, but go into system properties and unistall the video card.
Restart again, and install the drivers if needed.
Hope it helps.=)
Posted on Apr 09, 2008
SOURCE: monitor out of range
plz i have problem,,need help !! when i lanch vegas 2 game the monitor turn of and i see msg Out of range " freq,,",,,>> how to solve this problem plz
Posted on May 30, 2008
texsax
SOURCE: While connected via VGA cable
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
www.texsax.com
Posted on Dec 14, 2008
I have an old monitor P/N TL561-RU and I am trying to use it with a cctv camera and recorder.
The signal strength or format of the signal from your playback device does not mesh with the monitor's capabilities.
As an example digital signals will not show on an analog monitor.
Mar 26, 2014 | Relisys Computers & Internet
Out of range 64.0 KHz / 60 HZ
It might be because of wrong screen resolution. This problem can occur because of hardware as well as software change.
To rectify this issue you will have to set your screen resolution to lowest visual settings. For this purpose you can try restarting your PC to safe mode and then modify your screen resolution.
Sometimes setting your monitor to factory defaults can also rectify this issue.
You can view http://www.techyv.com/questions/why-do-i-get-out-range-message-my-monitor for more information.
I hope this would be of some help.
Feb 05, 2012 | LG Flatron L1515S 15" LCD Monitor
Looking for a driver for a CMV CT-529A
Chimei CMV monitors do not come with drivers and they are not available. They are plug and play devices.What exactly is the problem you are having?
Nov 23, 2010 | Computers & Internet
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
My monitor remains black
well your screens broken mate the only thing you can do is get a new one
Sep 30, 2006 | Amptron CMV-922D 19" Monitor
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
