Question about Xerox Office Equipment & Supplies
Machine will not make copies
I have a Xerox XC865 and a red light will blink and the machine will not make copies. I do not have the manual and do not know what it means. It is the symbol that looks like a triangled stack of small circles. What does this mean?
    President:
  • 2,072 Answers
Your out of toner and the machine cant set up.
Posted on May 21, 2009
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
Xerox phaser 6130: machine is about 2 months old,
Have you checked the Xerox support site? If not, try these links for your printer
Documentation
Drivers
Product Support
Troubleshooting
If this helps, click YES below.
Jun 30, 2009 | Xerox Phaser 6130 Laser Printer
Schematic of the Xerox XC865
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Cracked fuser drive gear for Xerox copier XC865
There is a metal clip that holds it on the roller. Look in the machine for it.
Jan 31, 2009 | Xerox CopyCentre C123 Copier
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
How can I replace the fuser on xerox xc865
it is pretty easy. You have to remove the lower front cover, located just above the paper tray, 2 screws to remove and pull forward.
Then there is one screw in the front of the fuser, It is a shoulder screw. Once that screw is removed you push the upper fuser toward the back of the machine slightly. It will pop off a locating pin. There are 2 plugs to disconnect and the fuser will come out once those are unplugged. The pressure and pressure cleaning roll just pop out of the frame once the upper fuser is removed.
Not hard at all.
Sep 07, 2008 | Xerox Office Equipment & Supplies
4 h error code on my xerox xc865
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
Jul 06, 2008 | Xerox Office Equipment & Supplies
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
137 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
